Charge Station Pro Installed today - won't charge past 3.2kw/15A
deltalightning
deltalightning
Andy
NE Louisiana
2024 Lightning
Yes, how? What are your big loads?
4500 square foot house with 3 ACs, multiple freezers and refrigerators. In the south where all 3 ACs run all day every day for 9mos of the year.
650 sqft guest house.
1000 sqft pool house.
1000 sqft boat house
2500 sqft shop, half of which is climate controlled.
12 acres of irrigated orchard.
Prodigy
Neil
2024 Ford Lightning F150 Lariat
I think everyone goes through this headache when your charger is installed. For some reason the charger has to have the latest firmware installed and the 2 ways this can happen is by “forcing it” to try to install it faster by turn off your breaker for 10+ minutes and then turning it back on and checking the charger or by supposedly waiting for that update to finally reach your charger over night through “over the air” update from Ford. I found the easiest way to get it to update faster is by turning the breaker off a few times for 10+ minutes each and it eventually worked like it was suppose to.
BlackLightning404
Larry
2024 F150 Lightning Lariat. ER, Agate Black
I'm having the same issue. Just had my Ford Charger Pro installed as well, charged fine for a few minutes then suddenly dropped to 3.2. I will check my firmware version.
deltalightning
deltalightning
Andy
NE Louisiana
2024 Lightning
This is exactly what i did. Multiple resets with intervals.
BarryGoyette
Barry
Photographer
The FCSP is capable of 80 amps continuous on a 100 amp circuit & breaker combo.
But if there isn't a need for the full capacity ie. model year 2024 Lightnings, then it's perfectly normal to install for 48 amps continuous load on a 60 amp circuit & breaker.
ha, yes… true. However last year when I had this exact same issue, two Ford CSR and their manager insisted that a 60amp installation was all the proof they needed that my issue was due to improper installation. (And refused to listen to “it’s in the manual, it’s in the marketing”). Luckily, whatever it was, it fixed itself.. either by the “unwrapping the cord trick” or a perfectly timed OTA update. It’s was the worst customer service experience of my life, and I’m glad they are no longer point blank blaming it on the customer.
roushf150
Roush F150, F150 Lightning
Just wanted to mention that I too had this same issue and, after myriad conversations with Ford/QMerit/the electrician who did the installation, Ford told me about the "known issue" and had me disconnect the charge station from my FordPass account. No clue why that would be necessary but it seemed to work.
FYI, the Ford rep I spoke with was reading directly from an internal Ford memo telling me what the necessary steps were: disconnect the breaker for 5m, remove the charge station within the app, turn the breaker back on. And, yes, I had cycled the breaker probably 5x previously and that alone never fixed the problem...
K6CCC
Glendora, Calif.
Two Way radio systems
Great thread. My FCSP arrived two hours ago. My expected project for this weekend is to replace the 6-50 outlet that I temp installed a few weeks ago and install the FCSP (and replace the breaker with a 60 amp). Yes, I installed the 6-50 with wire sized for the 60A circuit and I am qualified to do so myself.
SpacemanSpiff
Jayden
Huntsville, Alabama
2023 F150 Lightning Lariat ER, 2024 Mustang MachE Premium ER
I'm in the south too. That sounds like a pretty sweet setup. You wanna be friends? 🙂
ScubaSteve_TheReal
Midwest USA
Derivatives
Would it create any problem as a 2023 owner if I install one of these chargers at my 2700 sqft’ cabin on a 100amp breaker but then chose to dial it down to the 48amp setting on the selector dial at a later time.? I am considering that as a possibility as we are all electric on a 200amp panel. Our panel is close to being maxed out now. We are looking at adding a large hot tub at a future date. Dropping the amps I’m thinking might help if we get the new hot tub later in the year.
The Weatherman
South Central KY
Nope.
I believe it will support up to 100A. But not here, as I don’t have 80A of power available. My 400A service is pretty much maxed out at this point. So 60A breaker and 48A max charge it is.
Unless you have a fleet vehicle with the option or got Ford to sell you one somehow with the two AC-DC converter option, you are limited to 48A anyway with the 2024's even with the ER battery.
I doubt your running 400 amps all at same time. I would of opt for 80amp breaker, change the wire to #4 awg and #8 awg ground.
A 200A service is the usual standard for a residence, but larger homes may get 300A or 400A service. I had 100A service panel in my house built in 1969, but had to have the panel upped to 200A when I got my first EV in 2011 (2012 Nissan Leaf) because I was out of breaker space for my 30A EVSE, lol.
Note: Your electrical system should run at a maximum of 80 percent capacity.
Your electrical system should run at a maximum of 80 percent capacity. In this way, the demand on a 200-amp panel should not exceed 160 amps and 19,200 watts up to 32,000 watts, depending on the division of 120 V and 240 V circuit breakers.
https://expresselectricalservices.com/how-many-watts-can-a-200-amp-panel-handle/
NYCLABORER79
Sal
NYC
2024 FORD F150 LIGHTNING FLASH ER
Last year i had a 200amp service upgraded to a 400amp. Due to now these EV chargers so now we have 200amps running to the house and 200amps to garage.
Reactions: chl
