First Snowfall of the Year - Sensors Going Crazy
columbiaskier
Calgary
2022 Lightning Lariat ER
First snowfall of this year and front sensor alerts are non stop while driving. I was parked in the garage before driving so this isn’t related to sensors being completely blocked. Seems like they are picking up the flakes as obstacles.
This didn’t happen last winter. Might be just ice build up while driving but thought I’d post in case it’s and issue others might encounter.
We get snow once every 10 years or so here. Everyone freaked out, including my Lightning when it happened this past Feb. I guess it assumed living in a desert meant it never had to worry about the fluffy white stuff. Turns out, that's just the truck being true to itself.
Revenge
Ryan
2023 Lightning Lariat SR, 2011 Flex
Not snow related but my back-up sensor slammed on the brakes this weekend as I was backing into a parking spot. There was a light pole and as I crossed the shadow the brakes slammed on. Scared the crap out of me as I thought I hit something. Then I gave it a little throttle and finished backing up. First time it has done that.
snowy_91
James
Aurora, SD
2023 Lightning XLT SR
My Mache really hated snow on the front end, I did need to clean off the sensors after a snowy drive.
I appreciate safety features, but this one drives me nuts. I've still left it on to possibly save me, but baking into any spot with something behind you can trigger the auto braking feature. This can be turned off in settings.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
This happens a couple times a week as I'm backing into my garage everyday while parking it. It's a fairly tight squeeze with objects on both sides of my parking space. I guess 2 mph is too fast sometimes so now I go extra slowly. Its just like you said, the brakes are applied so strongly, it's like I hit a brick wall!
CRAIGC540
Craig
Moreno valley
F150 Lariot F150 Lariat lightning
Technician
Yeah I turn the rear sensor off when backing into my garage because it stops so hard. I can do it with sensors on but have to back in really slow.
Heliian
Snow/ice/water on the sensors will do it.
Just use the toggle on-screen when it's beeping to shut them off. Also works in tall grass.
Adventureboy
This is pretty normal. Snow or ice on the sensors (even heavier rain) renders the sensors unable to sense objects in front of them like having a hand over your eyes. We deal with that all winter up here in the Great White North. It happens with all cars, all brands with forward and/or rear-facing sensors for parking assist or adaptive cruise. The only fix that may help would be heated sensors, or changing the way they work through a weather screen that can be wiped (like our windshield). That would add complexity and cost that isn't needed for most but would be appreciated by some of us ;). In the meantime, drive on.
columbiaskier
Calgary
Interesting. I had no issues last winter. I would get the usual warning sensors were blocked but then that was it. It seems like thi
yes but the weird thing is this has never happened before on this truck. Previously I would get the sensors blocked warning and then that was the end of it.
It doesn’t appear you read my whole post. Did not happen last winter. I live in Canada too. The issue isn’t the sensors being blocked it’s the alerts that are happening every 10-20 seconds of objects while driving.
Adventureboy
I've been through two winters with my wife's MME and one with my Lightning and the warnings have always been annoying when they get snow/ice-covered but usually one or two and then they stop. They'll pop up regularly if you are trying to use BlueCruise or if it is slushy and the sensors are in and out as the slush slides off the sensors. If you are getting messages every 10-20 seconds while not trying to use BlueCruise or when they are obviously obstructed, then definitely that is an issue that perhaps Ford should investigate. We haven't had snow here yet so I can't say if anything has changed on this front on ours.
columbiaskier
Calgary
Yeah I totally agree. I’ll see how it goes. Maybe just some freak thing where a sensor was partially covered. I’m jealous of the weather in Ontario right now.
brtnstrns
Seattle
2024 Tundra Platinum Hybrid; 2022 Polestar 2 LRDM
This happens every once in a while in my Polestar 2 as well. First time it happened, I was certain I hit something because it was so violent, but it was just the car slamming on the brakes because there was a curb behind me.
Suppose it's better than actually backing into something but damn, it's annoying as hell when you're 100% certain there's nothing behind you but your brain is trying to figure out what you smashed into.
