- First Name
- Tom
- Jun 7, 2021
- Upstate NY
- 2022 Lightning Lariat ER, 2021 Mach-e GT
- Occupation
- Engineering Manager
Gas is still more expensive around me (over $3 for regular and still around $4.50/gal for premium which is what my previous vehicles took). On the flip side, if you are in a per minute state (vs. per kWh), DC Fast charging charging can be much cheaper - $0.24c/min - which at 120kW is $0.12/kWh!I don't recommend traveling with the lightning for several reasons: First off the few chargers there are often are out of service. Paying $.31-$.43/kwh isn't cheap. I have a platinum and on the interstate I'm lucky to get 2/mpk. At $.31/kwh that's a little over $15 per 100 miles. At $3/gal for gas comes to 5 gal which equates to 20 mpg. Not what I call economic. And if you pull a travel trailer you can cut your range in half.
If it's colder weather also expect a significant drop in range. Add to that at 2/mpk that's just 262 miles if you ran the battery empty, which you wouldn't do and to even come close to that you need to charge to 100% which is very hard on lithium batteries life span. And then there's the range anxiety wondering if you will make it to the next charger before you run out of power and will any of the chargers work when you get there. And stopping ever 3 hours to charge would be a pain, especially charging back up to the 100% as even fast chargers outputs are significantly reduced from 80%-100%. I know people do use them for travel but to be honest they really aren't that efficient or worth the worry when used for long distance traveling. The efficiency for me is getting 2.4 - 3 / mpk and only paying a max of $.12/kwh.
For real world costs, My Lighting can do the Albany area (NY) to Pittsburgh PA for about $35 in charging costs each way (real / measured - including costs to refill the battery at home. My old truck got about 15mpg on the highway and took premium, so it would cost $130-$140 each way. Huge savings - at least in my use case.
As far as charger availability and reliability, I haven't had any issues in the Northeast for any of our travels (Lots of trips in NY, travel to Maine, to Montreal and Thousand Islands in Canada, to Philly and Pittsburgh), though I do realize it is regional. Thankfully it should get better with time and network buildout.
As far as distance - I tend to hit charging stops about every 120 to 180 miles for a bathroom break or meal anyways, so I haven't had any issues there. The truck (and my wife's Mach-e) typically have more range than my bladder.
