Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
For those of you that don't know...someone figured out how to silence the external frunk beeping. Here is the video:
I did mine in about 45 minutes, and a good 5-10 minutes of that was just unloading/loading the crap I store in my frunk. You will need a torx head bit, I believe it is T45. Other than that, a drill or socket set is all that is required.
That will at least fix the exterior chimes. Don't think it will help with any crazy warnings inside the cab.
queuewho
Western PA
22 F150 Lightning Lariat SR
To me, exterior beeps don't bother me. It's the constant alert tones inside that do. Also, they are all the same, with the exception of the tailgate being slight faster-paced.
ivan256
Massachusetts
2022 Lightning Lariat ER
all it takes is one idiot to sue because they say they didn't get a warning the frunk wasn't closed or that is was opening or closing. all the beeps are for those idiots and sue happy people in this world.
This is a common take for things like this. But a louder or more insistent chime will not prevent any lawsuits, and whatever lawsuits there are will probably be settled whether the volume is increased or not.
In my opinion (since Ford hasn't said, we have to guess) it's more likely this was done as a term of a settlement rather than as a proactive guard against lawsuits.
Anyway... Disable updates and you won't get this!
ivan256
Massachusetts
THIS is what should have been in the update notes and the frunk chime the easter egg. Missed opportunity for some positive feedback on Ford's part. Gotta be some low level engineering in Ford with a big red mark on his forehead after the higher ups chose to go with the chimes being louder.
They (and other software developers - an illustrious club that I hesitate to mention being a member of) don't need any encouragement for leaving changes out of patch notes. Anybody distributing software patches that isn't forthcoming about what changes do is fully deserving of customers who refuse to install the updates.
I would certainly hope that they would mention any security changes in particular. Since if they bundle something security related in with a $^#&ing Frunk volume increase there are going to be lots of people driving around with a security hole in order to avoid being annoyed by beeps.
Carrot & Stick concept, everyone wants the carrot!
jdmackes
2023 F-150 Lightning Pro
Are these rolling updates? I've never gotten one on my truck, just want to make sure nothing is wrong.
MickeyAO
Mickey
San Antonio Tx
Looks like it is updating the IPC module.
ChrisCon
The Hamptons, NY
Full release notes because Ford doesn’t publish them-
Summary
Priority Update 22-PU0930-RBA-CHM for 2022 F-150 Lightning vehicles is now available. Quality Improvements include: - Updated Frunk Chime Strategy - Removal of brake assist warning pop-up - Mitigate erroneous Crosstrafic Assist pop-up due to incorrect configuration - "Emergency Tow Enabled" is now correctly called out instead of "Neutral Tow Enabled" in the popup. - Improved key off load (KOL) - Enables Low tire pressure warning to show up on Ford Pass.
swajames
CA
so after the last two priority updates that kept failing multiple times before finally getting them to work, this one at least installed right away with no drama.
Monkey
Somewhere in the mountains
Half of their problem is they shouldn't stop the frunk from closing just because you've taken the truck out of park. Finish the close regardless of Park or moving to drive. I've experienced it. Louder beeps is just annoying, don't be so short sighted to stop the close and have a need for a notification. You truly have to question the brain power behind these decisions.
TIL - you can shift out of park with the frunk open. Really? Seems like the truck should not even allow that without a manual override option on the screen. I think too many of the features and issues of this truck are being held back by all the legacy crap of a cobbled together system...
ChrisCon
The Hamptons, NY
And I can’t get mine to install . Fifth try so far.
swajames
CA
Yep, I was one of the lucky ones this time around. Hopefully yours will figure itself out soon. Good luck!
Usually on the front end of these releases, but had no indication on this one until I just went to the truck to check. Actually says it is downloading. The truck is or should be connected to Wifi, but I'm surprised as I thought downloads seem to be almost excluding on Cellular.
Maybe they are making some headway for a change and getting downloads over Wifi working.
Ford F-150 Lightning Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits IMG_4361
BennyTheBeaver
BennyTheBeaver
2023 Lightning XLT ER
I've (previously) had it work on both wifi and cellular. This was the first update that had requirements (like the vehicle to be off).
Maxx
What an easter egg, didn't even mention it in the release notes!
Nice but messy. Following makes a lot more sense to me:
Ford F-150 Lightning Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits 1689312313076
