Tow to charge?
Jodokk
Me
NC
22 Lightning Lariat ER, Agate Bl., Max Tow & AT tires. UnderCover Abyss Tonneau
College Professor
Hey everyone!
I am planning a business that may require me to have 2 vehicles and one of them will be my 23 SR XLT. It will likely be remote places, so I wonder:
Has anyone tried to tow your Lightning to charge it?
I saw some videos and thought: if I have a HD diesel truck, it may even be cheaper and quicker to tow charge the Lightning for parts of the journey. Thoughts? Experiences?
Edit:
Turns out that some places, including BC Canada, it is illegal to tow a vehicle that has persons inside. However, if a friend of a friend ever decides to go ahead with this heinous crime in some remote places, I'll ask them for the numbers and experience, for science.
The "heat event" may make the experiment an expensive one, but it would certainly make for an very interesting video. I'd definitely watch.
Ecstatic
Bret
Spokane
‘03 Highlander, ‘83 Landcruiser, ‘22 Lightning Pro
Temporarily retired
It’s a very easy experiment to do by simply using a very steep hill and letting gravity act as the tow vehicle. If it’s steep enough and long enough you’ll get massive regen.
jjerabek
Maros
Vancouver
Ford F150 Lightning XLT
Let us know your actual numbers when you give it a try.
Thank you for the theory and math, I was doing similar calculations haha. If a friend of a friend ever tries, in a remote location where it's safe ... for science ... I'll ask them for the numbers 🤫
HHI-Lightning
Rick
South Carolina
F-150 Lightning Lariat ER
Why not have a tow dolly on the lead vehicle, put the Lightning front wheels on the tow dolly, and use the Lightning’s rear wheels for the regeneration?
That approach would provide a solid connection between the two vehicles (greatly reducing risks) while still providing access to the rear wheels for regen.
jjerabek
Maros
Vancouver
With 4 wheels on the ground, it pretty much just simulates going down an endless hill regenerating through and through. I wonder if doing the dolly with just the rear motor regen wouldn't freak the computer out. I guess there is no other way to find out besides trying.
Yellow Buddy
Mid-Atlantic
Smart Ass
It only gives you a fraction of the experience. There aren’t a ton of really steep and consistent downhills that goes for miles on end.
I’ve harvested downhill regen through the Appalachian and they pale in comparison to how quickly it recharges when being towed. That was the one thing that was unexpected was go quickly it charged while being towed.
neonoggie
Cas
Nashville, TN
F150 Lightning
Data Scientist
I am so looking forward to this You tube.
Engineering Explained did this with his Tesla Model 3 and the Straight Pipes Ford Raptor. The fuel economy was terrible as one might expect, but it definitely DOES work and could get you out of a pinch if you couldnt call in a tow or a portable charger.
jjerabek
Maros
Vancouver
I forgot about that video! And in conjuction with what @Yellow Buddy said, I bet that if you have 2 vehicles going anyway and one is an HD diesel truck. It's gold. If a Tesla can do 1kW in 1km, I bet Lightning can do more, and a diesel HD truck can pull a lot more efficiently than a Raptor.
Ragman
2023 Lightnings - SR XLT, ER XLT, ER Lariat - 2024
If you’re going to tow it to charge may as well plug it in with 120 to cab outlet (or 240v if other truck has pro power equivalent).
I’d be curious what the efficiency is of a eco boost 150 using its pro-power to charge a Lightning if it’s stranded.
BBB
Britt
f250, focus, cmax energy.
Hey everyone!
Edit:
Just buy a portable generator with a 50 amp 240v countinuous rated plug, not peak. Thats what i plan on doing for remote areas.
Yellow Buddy
Mid-Atlantic
Smart Ass
The problem is the amount of time needed to charge. Even if you had a 20kW generator putting out 80A, it would take 6 hours to fill from empty. It’s a good alternative if you were planning to stop anyway but not a great one for a constant fuel source.
Tclark5
Terry
2022 Lightning Platinum
Hey everyone!
Edit:
Jseis
SW Wa
A mile huh? Laggards! :) I used to push start my dead VW all the time - put it in neutral, give it a good running start (slight downhill never hurt ) jump in the moving car and pop the clutch with the ignition on! Would start right up every time - except that one time when the alternator was shot :(
Haha. It was dead dead and we tried bump starting it. Dragging it a mile did the trick!
met some good friends at college who all parked their cars on the same hill: 50’s trucks & station wagons, 60’s bugs, etc. all stick of course
jjerabek
Maros
Vancouver
I heard once that real men/women drive cars with 3 pedals 😉
that sounds like a real easy, dreamy idea, but it doesn't hold merit:
A) any 'portable' generator, if there even is such a thing, with 240v output, CONTINUOUSLY, for HOURS on END, at any amount of output, such as 30amps, would not only take a HUGE amount of fuel, but would not be 'portable' for any such a reasonable situation... it's just not reality. The weight of the generator, and the additional 'fuel' you now would need to CARRY in the truck, negates all the 'power' you might be able to generate. You've now wasted MILES to get where you are going, so you actually come up SHORTER than if you had NOT carried it to begin with.
