Power Up-3.4
LightningShow
MA
'22 Lariat ER
Product Development
Mine is giving me the warning about the vehicle being unusable during the update. I’m waiting until i get home from my roadtrip on Sunday before i let it update. I can’t risk a bricked vehicle 500 miles from home.
ErichKeane
Erich
Gaston, Oregon
22 F150L Lariat ER, 23 Mach-E Prem/SR, 90 300zxTT
Principal Compiler Engineer
Anyone else noticed the Nav "quick tile" in the row of recent apps/screens is no longer there by default? Every time I get in now rather than just being able to tap one of the quick tiles I have to go up to the Apps button, then Nav, then it shows up as a recent/quick tile.
I guess it's only one extra tap, but still, seems like it should be a fixed/default quick access tile...
YES, so glad it isn't just me! I thought I messed it up somehow. Happened under 3.3.1 for me as well though.
RainorshinePNW
Yeah, true- this change did happen after a previous update or two, but I thought it was just me and/or would have been fixed with 3.4. Before 3.2 at least it was always in the quick access row, if not the default mode (for me) when I ended one trip and started another.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Exactly what I have experienced. I updated in the middle of my drive back home from work at a stop and could tell there was something different. It’s almost as if you have to fully let off now vs modulating. Hard to explain.
YES!
Ford is actually listening to me!
Can't wait to turn 1PD back on and try it out because the old version would regen too abruptly for my driving and not useful when reversing.
I am still on 3.2 so can't wait for the 3.4 !
FlasherZ
St. Louis Metro
I am hoping to have a bit more blend, myself...
I do recall the early Tesla updates, though, where people SWORE up and down that they changed the regen profile, with Tesla specifically coming out to say "we didn't, we swear!" Be careful you're not looking for something that isn't there. :)
Firestop
Firestop
Completed the update this morning….now my truck no longer cas “see” any WiFi hotspots, including my home mesh network to which it was previously connected 🤔
Any thoughts or ideas?
  • Sad
LSP
Scott
Orange County, CA
Lightning Lariat ER, Audi e-Tron
Mine is doing the same thing. I was going to try to reload my location to see if that would fix it, however it said that there were no charges yet at that location? I am charging it now and I am going to try it again tomorrow morning. Apparently, something is going on here.
I have charged 3 times since the update and I am not able to add back my home charger location. It keeps telling me that I have to charge at a location before I can add it. I have yet to charge away from home but I plan to go to a local EA charger and if if it will recognize that after I charge there. If I can’t get this fixed I’m stuck with a 100% charge at home unless I manually unplug at 90%.
kwalt21
Kurtis
PA
22 F-150 Lightning Lariat ER
The 3.4.0 update was to the following modules:
BECM (Battery Energy Control Module
PCM (Powertrain Control Module)
SOBDMB ( SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE B)
SOBDMC (SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE C)
Explains why vehicle inhibit was required!
asu2011
WA
2019 F150 XLT, 2022 Lightning Latriat (on the way)
Updated to 3.4 then I had a weird bug/glitch where the interface for the heated/cooled seats changed. The first time I drove the truck after the update the interface was two horizontal boxes (one for heat one for cool) and you could press to cycle through levels. Now it is back to the standard slider.
I was bummed because I really liked the boxes as I find the slider to be clunky.
Firestop
Firestop
Following up on my own post, I drove it around town running some more stop/go errands. Plugged it in to my newly installed FCSP to test it…..the problem self corrected…I now can see every WiFi network in the neighborhood…..and, it reconnected to mine without the need to re-enter the password🤗. Mystic forces….
BTW, I think 1-Pedal is improved with update…smoother, though it took about a hour of Stop & Go to get used to it…..
Marcoux
Stéphane
Ontario, Canada
F-150 lightning XLT
Definitely something changed with one pedal driving. Major improvement in my eyes. That being said, still feels a bit clunky when doing stop and go at low speeds (like in a drive thru). Feels like the break pads are sticky or something, really hard to explain...
Anyone have experience adding a phone after accidently deleting the phone pairing in the truck pairing list as well on the phone paired history?
I tried restoring the pairing, but the truck does not appear as a pairable device on my phone.
Not sure that this is a 3.4 update issue.
Ford Senior Master
Pell City, Alabama
Lightning Pro, 2023.5 MachE on the way
Service Manager
Make sure and delete it from truck and from phone. Then try pairing again. If you can't get it.
metroshot
Pat
Montclair, CA
Networking Tech
I am so looking forward to the "new 1PD".
Haven't received my updates - still stuck at 3.2......
