I can't set one, either. It asked me to set one up the first time I was setting up my truck but I dismissed the prompt because I was doing something else when it popped up and now I can't figure out where it is in the settings.PAAK works great for me but I can’t set a backup passcode which makes me too afraid to rely on it!
It will not be in a power up update. It comes as a separate update. When? Nobody knows and ford won’t/can’t tell you. Who gets it? Here again seems random The RFA module firmware needs updated. Dealers have the update through the FDRS system but we’re told not to do it along with many other firmware updates the early builds need.Weird 6/18 blend date. Most recent update and no PAAK.
under general u can report an issue, i pressed something related to update not working and got the PAAK update couple days later, but so did alot of other people who didn't do what i did. worth a shot?It will not be in a power up update. It comes as a separate update. When? Nobody knows and ford won’t/can’t tell you. Who gets it? Here again seems random The RFA module firmware needs updated. Dealers have the update through the FDRS system but we’re told not to do it along with many other firmware updates the early builds need.
I am still waiting as well.
Nice….haven’t found that setting on the iAppI got the update and my PAAK works so far. Set it up on my Samsung Z Fold. Ford Pass had a line that asked me to setup phone as a key. My app also has a walk away lock setting.
I have that setting as well, but it does not cause the truck to lockI got the update and my PAAK works so far. Set it up on my Samsung Z Fold. Ford Pass had a line that asked me to setup phone as a key. My app also has a walk away lock setting.
That's because it doesn't exist for the Lightning. Yet (hopefully)I have that setting as well, but it does not cause the truck to lock
That setting is about notifications relating to walk away unlock. Probably for the Mach E.I have that setting as well, but it does not cause the truck to lock
