Amps
- Feb 21, 2022
- Mid-Atlantic
- Bolt
Your occupation is electrician?Read the description 22kw.
I bet it would work if connected to one leg of a 480/277 wye system. Not that I’d try it.Correct. You would need 275 V to get the 22 kW rate...they may have designed their equipment to HANDLE 275 V, even if it is not offered basically anywhere in the world.
Totally bogus - Amazon no longer has this available btw - probably because of the misinformation.
I just did this screenshot on amazon.Totally bogus - Amazon no longer has this available btw - probably because of the misinformation.
How did they come up with the 22kw?
Well maybe like this...
220V is a European standard voltage, in the US it is nominally 240V.
To deliver 80A (the actual amperage of the charger) you'd use a 100A circuit (using a 125%) because there are Ohm's law losses in the wiring.
So using Watts Law, 100A times 220V with a power factor of 1 (because it is a resistive load) is 22kW the number in the ad.
But that is a completely misleading, idealized black-board calculation.
In the real world, a 220V, 100A circuit in the breaker box wired to the charger is not going to deliver 22kw to the Lightning even it is only a few inches from the box, there are Ohm's law resistance losses in the wiring, in the charger, in the charger cord connecting to the Ford, etc.
And as others have pointed out, 19.2.kW is the max the Ford can utilized under optimal circumstances anyway.
One has to be very careful these days with things being sold on Amazon - if it seems too good to be true, it is a probably a rip-off.
Yep, I saw this on Amazon and on their website. One of the following three cases must be true:I just did this screenshot on amazon.
The Ford Connected Charge Station is also made by Webasto.Given what PrimeComTech has claimed, I wound't trust anything that they say:
- The maximum Level 2 charging power for J1772 per the standard is 19.2kW; any EVSE that claims to deliver more than this is either out of compliance with the J1772 standard, or is making up funny numbers for marketing purposes.
- Siemens makes the Ford Charge Station Pro, and Webasto makes the Ford Mobile Connector; it is unclear who makes the Ford Connected Charge Station.
- The maximum charging power is controlled by the vehicle, based on the power its on-board battery chargers can handle. Regardless of the power supplied by the EVSE, the vehicle will not charge above its maximum acceptance rate:
- All SR Lightnings have a single 11.3kW charger, and
- All ER Lightnings have two 9.6kW chargers for a combined maximum of 19.2kW.
The SR could use the 80A FordCSP if one wanted to backfeed the house, but the charge rate would need to be set to a maximum of 48A, right? But the Primecom 80A does not have the CCS plug!If you have an SR Lightning, there is no point in buying a charger over 11.5kW (a 48A charger on a 60A circuit)
Yes, the one reason to use the Ford Charge Station Pro (FCSP) with a SR truck is if you've purchased the Home Integration System (HIS) and want to use the FCSP to feed high-voltage DC to the inverters in the HIS for the backup power feature.The SR could use the 80A FordCSP if one wanted to backfeed the house, but the charge rate would need to be set to a maximum of 48A, right? But the Primecom 80A does not have the CCS plug!
I have my SR on the Ford 80 amp charger, installed on a 100 amp breaker. My max charge is always 10.2 kw on the moneyRight - the max charge rate of an ER is only 19 KW, SR is 11 KW.
Yes, mine has always been between 10 and 11 (never reached 11)I thought the SR battery maxed out at 11 KW on L2?
Not true. But if it was, it would explain craptacular quality of all 3 Ford EVSEs.Primecom tech is the company that makes the Ford charger.
