Powertrain Malfunction/ Reduced Power
Blaine
Massachusetts
22 ER Lightning Lariat, 22 Tahoe RST, 23 BMW X7
Construction Planning and Sales
Update 3: Service advisor contacted me today and told me the battery came in today 10/18/23 and they should be able to repair the truck and get it back to me by Friday! I was pleasantly surprised that it came in less than 2 weeks, maybe because this was a brand new truck and given that I escalated the issue to the BEV teams might be why I got the battery so quickly.
As far as compensation for the time in the shop, the BEV team offered to pay for my first truck payment which is nice. I also wanted to ask for some ford pass points or extended warranty since this issue was discovered so early.
Has anybody had any luck getting ford pass points or a extended warranty as far as reimbursement for this claim?
How long did it take for the battery to get to the dealer? I am one week into waiting for a battery module.
hikinbengal
Bay Area, California
Lightning Lariat ER, Outback, Jeep TJ, Audi A3
Engineering Progam Manager
@Ford Motor Company
I was towing my airstream a short distance to prepare for this weekend’s trip and received a powertrain malfunction/reduced power error. My power was reduced to 53% and I had to limp home at 15mph. This my second occurrence on the truck about a year apart from the first repair.
When I got home, I power cycled the truck and no errors returned. I need to understand at what point will this truck die and if I need to take it in before I tow again.
Ford Motor Company
Official Ford Account
Ford
F-150
@Ford Motor Company
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
thrawn2k2
FL
@Ford Motor Company
Scary - Glad you were able to limp home
Blaine
Massachusetts
Still no battery to the dealer. The dealership says there is no way to track what the ETA of the battery module is to the dealership. Called the BEV team and said they would try and have an answer by MOnday on when I can expect the battery. I am a Aug 22 build (for the tracker).
sstevetx
Steve
When I had it done, they ordered it on a Monday or Tuesday and had it by end of day Friday. They told me it was a blackbox on the status, because they were kept in the dark. They said the part just shows up and then they have to figure out which customer it is for. Even the Ford rep handling my case couldn't see the status. Work with @Ford Motor Company if you aren't already. They will assign an case and someone from their team will work with you and the dealer to get it as expedited as they can.
Atxlt
Tim
Austin
F150 lightning xlt
Well folks,
I got the first error.
No noticeable performance issues but got the power train warning and a needs service message.
Taking the lightning in Monday.
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_6651
kajjwood
colorado
ford lightning 2023
I got the dreaded "Powertrain Malfunction/Reduced Power" Alert at around 950 miles on the odometer. I had the code pulled prior to dropping it off at my local dealership which was Code: U3513 - High Voltage System Interlock Circuit 'B' Low. I have not had any power drop yet. Very disappointing.
2023 Platinum Lightning with under 1k miles
What does this code usually mean? What usually needs to be replaced?
The Weatherman
Dean
South Central KY
It’s related to defective HVB module(s).
If it’s accurate you will likely have to have a module replaced.
Blaine
Massachusetts
I love the truck but this is starting to be concerning how widespread these issues are. Made contact with @FordMotorCompany and have a case #, hoping this will help things along. the 2.7 ecoboost XL rental is not cutting it for me. :rolleyes:
4% may involve a module concern.
Blaine
Massachusetts
what is that based on? Polling on the forum or from ford? Not discrediting or saying its wrong, just curious where it comes from? Our fleet has 12 lightnings and 3 have had battery modules replaced. two were built on the same timeframe the other was built nearly 10 months later.
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Well the only thing the BEV team and a case number did for me was offer to pay for a rental truck (which I do appreciate). My service manager called me everyday to give me status saying no ETA on parts, which is the same thing the BEV team told me. Not sure of the value there. Ultimately this last module replacement only took 22 days, which I guess I'm happy about.
