Power-Up 4.2.1.1 - Some Good Stuff Here
itdwebman
Northeast
Thanks all My update was not completed - and now activity since I received that notification late last week?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
That message “Ford will make a new update…” usually means that it has expired and you’ll have to wait until it is pushed to your truck again. @rugedraw can check your history to see what caused it to fail but it‘s about 90% going to be 12V battery related. Have you had the BMS replaced (CSP23B70)? If not, that will probably fix things.
itdwebman
Northeast
Thanks for this information. BMS CSP being done today. How do I check my history as the only notification I have received is the screenshot I shared.
A competent Service Advisor (suppress giggle) can tell you your history. Or contact the member mentioned via Private Message (i.e. click his name and Start Conversation). Give him your VIN.
The only way to check OTA is using Ford's PTS website. Post or PM me your VIN and I can provide it to you. The notification you are seeing now most likely means the update you were sent failed for one reason or another. With your VIN, I can check that, too.
Merged several posts from a newer thread into this one and adjusted the title to reflect the theme, as it's been the same since last summer as it is now in recently reported updates.
For those who missed the distribution, hopefully it will recur in the coming weeks.
WildBlue
Somewhere
2024 F150 Lightning Flash
Mine says ready to download and has been that way for a week. Truck has a wifi connection and auto updates are on. Nada. Zip. Zilch. Nice OTA rollout, Ford.
itdwebman
Northeast
Got mine installed yesterday without a hitch. Did a check on my 12V battery before attempting it.
Edit: 4.2.1.2 install complete on Feb.16, 2024
Great news - I had a bad update/server push from Ford - rejected by Truck.
BTW - how did you get the SOC and 12V battery information on your screenshot?
rtk11226
Rusty
Houston Area,Tx
2023 Ford Lightning/1991 Chev 1500/1976 Corvette
Retired IT/Engineer
I'm using Car Scanner Pro with the Vgate OBD2 scan tool.
Ford F-150 Lightning Power-Up 4.2.1.1 - Some Good Stuff Here reply
1995hokie
Washington DC
‘23 F150 Lightning Platinum
I have a MY23 with 2/23 blend date. Have been in a similar path to Jim Lewis (same update order with similar time gaps just 6 months later as I bought the truck 6 months later). Last update was on 2/1/24 to power up 6.2.0.
6.3 and 6.4 is up next for me hopefully.
Jim Lewis said:
Might be a YMMV issue. My build date was 02/23, but my truck wasn't complete until 04/23 because of the Dearborn battery fire. Took delivery 5/5/23. Got Power Up 4.2.1.1 on 6/12/23, 4.2.1.2 on 6/27, 4.2.2.2 on 7/19, 4.2.3.1 on 7/28, then no updates until the end of October when I got the Digital Owner's Manual and Power Up updates 6.1, 6.2, and 6.3. Got revised 6.2 on ~12/1 (didn't show up as a FordPass message). And 6.4 just today.
I got revised 6.2 today. So still proceeding on a similar schedule. Today’s update was meaningful as it provided the Apple Maps charger integration.
Ford F-150 Lightning Power-Up 4.2.1.1 - Some Good Stuff Here IMG_2569
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Looking forward to this update! I am on 6.1. Does anyone know if apple maps will precondition enroute to a charger?
detansinn
United States
I got the 6.2 update overnight. 👍
I would like to add that I saw hardly any updates until they did that 12V battery monitor fix bulletin. I've now seen 2 in the past two weeks. So, if you've been dragging your feet on scheduling an appointment, get that done.
medmondson
California.
2023 XLT
Got 6.1 last night, but same situation. Got the 12v recall completed exactly two weeks ago and have gotten 3 updates since.
I'm only guessing, but I think all the latter half MY23 trucks have been held back in the bullpen while they tweaked out the most recent buggs and got the LVB/BMS solution rolling, now that it's out, they have opened the floodgates with a little staggering built in just in case something goes sideways again.
Wishing everyone continued luck catching up to the latest updates available.
