Hammick
- Jun 21, 2023
- Kansas City, Missouri
- 2022 F150 Lightning Lariat ER
Thanks. Even if we have to drive at 70 mph for the 200 mile stretches it sound like the EV9 would shave of a ton of charging time vs our Lightning ER.The superchargers are going to be near worthless on the EV9s, because of the way the packs are setup; we won’t get anymore than 80kW until the V4 SCs roll out.
I replied to you on the Kia forums as well, in a worse case scenario - heat usage, headwinds, elevation, and a 80mph average - no, I don’t think it can reliably.
And just to clarify, I’m using true 80mph average according to OBD reading. We need to get on the same page on that as it can change the data drastically
Meaning if I have stretches of 60mph, I would need to go 100mph to average 80mph.
If we’re not using true 80mph average and we’re talking normal driving on local roads and on the highway set the cruise to 80mph, I find the OBD reports those as averages closer to 65-70mph.
This trip for example, I went 176 miles on 75% SOC, varying elevation, moderate headwinds and ended around 3-5%.
A quick glance would make you feel like that’s a 75mph average. I even touched 90mph at multiple points. The trip planner shows this as only a 63mph average.
So based on that, do I think you can do a true 70mph average, in the cold, with headwinds, with elevation, and go 200 mi on 80%? Not likely…I think it would be too close for comfort for most folks.
Hope this helps.
Wife and I are going to test drive one in August. We have 14 months left on our I5 lease and it was a "single pay" lease so I don't see any way of getting out of it early.
Assuming I have our adapter by November (was supposed to be July now August) I think we will head North to Miles City at Spearfish and avoid Sheridan.
I will try that on the way home. We always travel with a 12v car fridge so I'll keep a wet towel in a zip lock int eh fridge.Try wrapping the charging handle in a wet towel in the heat.
My first charge stop was in Council Bluffs, IA and the first charger I was on caused a charge fault. The handle was uncomfortably hot. I switched to the other cord and it faulted out but wasn't as hot. Moved to a different charger and had one charge fault. Started over and I was able to finish. This was at 8:30 am so I doubt the outside temps were the issue.
Sioux City and Sioux Falls both have brand new EA chargers and I experienced show charging at those as well. So I figure there could be three possible explanations.
- EA had derated these chargers
- Ford did something to the charging speeds in one of the OTA updates
- My truck has a problem
