CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery?
CypherBlue
Cesar
Austin, Texas
2023 Lightning Lariat ER
Software Engineer
Hey all,
This past Friday, my dealer sent mobile service to update and resolve the front sensor issue. I did notice he didn't hook up power to the 12v until an hour into the update. It took about 2 hours for it to update. While the front sensor issues seem to be resolved, I have noticed the sensor beeps and cross-traffic alerts seem to be coming from a single lower-quality speaker instead of how they used to through the whole sound system. Also, whenever I park the truck, the center screen displays a message that it is shutting down to save power. Which makes me think the 12v battery is low. I threw a battery charger onto the 12v, which was a bit low. Still, even after fully charging it up, every time I turn it off, I get that system shutting down to save battery message, and it worries me because then I won't get any OTA updates, and I want the SoC update. Could the 12v battery have gone wrong? Any ideas?
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? 5CE931A1C5B8_20240913224846957
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_1428
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_1431
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_1464
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_1468
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_1487
Adventureboy
If your mechanic drew down the battery for the updates, you may just need to charge it fully. It will take quite a while on a 4Amp charger, or about an hour driving.
I had to replace my 12v battery in my '23 Lariat already 6 months ago. Have you had the CSP 23B70 done on the Battery Monitoring System (BMS)? That was the cause for many warnings I was getting.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Charge it to 100% using your charger, let it sit overnight, and put a multimeter on it and check the voltage. If it won't hold a charge they could have killed the battery, but that seems unlikely unless they ran it all the way down to nothing.
Al_V
Allen
Canton, Ohio
Is the 12v battery covered under the 3 year warranty?
ThunderSnoww
Kevin
Detroit, MI
2023 F-150 Lightning Lariat ER Antimatter Blue
Had the CSP 24B56 work done on my '23 Lariat ER today by my local dealer. Now I'm also having 12V battery issues. All four times I've started the truck post-module updates, it's had the "System Off to Save Battery" message on the Sync4a screen. Also, no cabin lights, an empty dashboard, and loud start-up chime before driving. I checked my voltage before and after a 33 minute drive (fourth trip today) and the battery charged by about 0.13V during that time. Anyone know what the 12V battery needs to be to for the BMS to consider things "normal?"
If things don't go back to normal within the next day or two, I'm taking it back in.
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_7797
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_7804
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_7805
Ford F-150 Lightning CSP 24B56 Front Sensor Fix, Done by dealer but now an issue with my 12v battery? IMG_7803
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
I’ll jump on this thread too. Same 12V battery issues here too. After a week of commuting 100+ mile round trips, it’s still the same. I can see in the notes from my visit that the battery was tested and passed before the update so I know it was good prior. I’ll make a service appointment and see what they say.
Mike G
N. AL, USA
Before your next commute do the BMS reset procedure and then see if that helps.
Press the start button without putting your foot on the brake to put the truck in Accessory mode.
Flash the high beams 5 times with the stalk.
Step on the brake pedal 3 times, and watch the instrument cluster for the red battery icon to flash 3 times.
Press the start button to shut the truck back off. Pause.
Start the truck as normal and go for a drive.
See if that helps.
If it doesn't, make an appointment with the shop to get your 12V battery tested and probably replaced under warranty.
MapleMan650
I.T.
See if that helps.
Thanks for this tip! My truck is at the dealer now and they tested the battery and said it failed so they will replace it under warranty. One weird thing, they said in my trucks log the battery has been low for a month, but I never had any symptoms before CSP-24B56. They are also going to replace the same BMS sensor they replaced for CSP-23B70. They are going to hold it over night to keep an eye on it and then drop it off tomorrow.
ThunderSnoww
Kevin
Detroit, MI
Glad to hear you got a new battery and BMS under warranty. My Power Save issues seem to have gone away (at least for now) on their own without doing a BMS reset. Posted a few more details here.
Ragman
Good to see an actual Ford 12v solve, talked to our service manager locally when ours started throwing warnings and not starting - he said 12v is common issue but Ford makes them put it on a Ford tester that does the pass/fail and they usually pass until they are in really bad shape.
Apparently not unique to Lightnings, we rented a Jeep on vacation with start/stop and it has two batteries. Wouldnt start, the CAA guy showed up said he boosts these new vehicles all the time.
JonS
Jon
Tesla Model S Plaid, Tesla Model X, F150 Lightning
Very interesting. Just had the dealer fix fine today and noticed these exact symptoms when I picked up the car. The update did fail multiple times so the battery could legitimately be run down.
MapleMan650
I.T.
Update for you all. The truck was dropped back off today, and I read through the notes from the service department. They think it’s my dash cam that caused the issue and not the update. Given how many posts there are on here after the update, I would disagree, but they said to try leaving it unplugged for a few days. I’ll give it a shot and see 🤷‍♂️. I’ve had my dash cam for about a year now, so I don’t think that’s it, but we’ll see! I’ll upload the record tomorrow if anyone wants to see the complete visit notes.
JonS
Jon
Took the truck out for an 2 hour drive and this issue resolved itself. I’m pretty sure the battery wasn’t actually run down as I plugged in a battery charger and it went immediately to maintenance mode.
doomrabbit
Robert
Davis
Ford Lightning
I also had the front sensor maintenance done (feels like 2-3 weeks ago), and just tonight got the following message in FordPass:
Electrical System Drain
Service Required
There is an electrical drain in XXXXXXXXX, possibly caused by aftermarket device(s). If that's not the case, please schedule service soon.
I don’t have any aftermarket devices tied to power. One thing I noticed the other night though - the rear ambient light, the one that shines down on the rear floor from the rear of the center console - that light stays on now after exiting and locking the truck. I don’t remember that happening before. It eventually goes off but not for several minutes; turning off ambient lighting will turn off every other accent light in the cabin except that rear center floor light. I’m wondering if a recent update or that front sensor fix somehow introduced this rear cabin floor light bug.
