OTA Update 10.x / 10.1 / 10.1.1
Jasin
Jasin
2022 Lightning ER Lariat
Pretty sure it was BCM
Do any of you 2022 owners who got the 10.x OTA have NOT had the 24B56 front sensor CSP performed? I read a comment on Reddit this morning that said OTAs are locked out until this CSP is performed. If that has been said on this forum, I missed it. I have held off on getting this CSP done because I do not have great confidence in my local dealer in doing this correctly, and I've seen multiple people post about having their truck bricked because the tech didn't use a 12V power source (or other various reasons). If the thing about having OTAs blocked until that CSP is done, I'll have to take the risk.
I had the front sensor CSP done months ago, not a single update since. In fact, in over a year I've had two OTA updates. Santa left me a lump of coal to go with the rock I got while trick-or-treating.
I have not had that update. It was not a prerequisite for me.
boggle
CT
MY23 PRO
Received 10.1.1 this morning on my '23, no CSP 24B56. Will give AA/Google Maps a shot this evening.
Update: Seems to work as advertised, at least I can see the current and arrival percentages. Will need to try a longer route with requisite charging and see which stations it points me to. Also seems we need to enable the Tesla chargers manually per Ford's Q&A page, will check what mine is defaulted to.
luebri
Neenah, WI
I was afraid I'd pay the price for taking vacation. Returned this evening and 10.1.1 installed on the way home from the airport.
Well, the first string bench is nearly empty ...... waiting patiently
Ford F-150 Lightning OTA Update 10.x / 10.1 / 10.1.1 1734272044571-zr
GoHawks
2022 Lariat Lightning ER
I finally received 10.1 on 1/15 I think. Unsure on the exact date as my app had no notification or message other than plug and charge was enabled on 1/15. I disable plug/charge so I can take advantage of Tesla/EA membership prices. 22 Lariat.
electricpig
Tim
Northwest Arkansas
F150 Lightning, Tesla Y
Fyi, if you are an Android user, that update also enables Android Auto to make trip planning using your trucks parameters much more like Tesla trip planned. It gives you estimated SOC on arrival, charging stops, estimated time at charging stop, etc. I have had a very positive experience using AA since the update.
CRAIGC540
Craig
Moreno valley
Technician
Any word on 22 getting the charging rate displayed on the dash?
Formerly
NY
Ford Lightning 2022
Construction Estimation
Couldn't believe I couldn't see the charge rate the other day, seems so basic
