majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
It's completely ridiculous that there is an expectation that they'll kill a 12V LVB during the process of performing module updates.
If the tech is using a Rotunda, Clore, or similar battery charger with a power supply function there is no reason any 12V battery should be harmed during the process.
Simply put, if they killed the battery, they didn't follow instructions, Full Stop.
It is crazy to think that trained mechanics are doing this, but here we are. I was the victim of this on my first service appointment. They replaced the AGM, on my new lightning. The one thing I made sure I did when I started doing my own module programming was to have a high quality, high amperage power supply. Not just the tiny tiny Pro-Logix one, but one that can hold the battery through hours long programming. Have never had any issues just following that.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
I have my CSP fix for the front sensors scheduled on Monday. How do I gently tell the service department to hook up the 12v to a battery tender without sounding like one of those a-hole customers who thinks they know better than the trained technicians? 🙂
majorgearhead
Summerville, SC
I don't think there is a good political way to do this unless you are buddies with the mechanic. If they kill the battery, you get a new one. It's a waste, but what can we do. It was on the first iteration of that front sensor fix that they killed my battery. I pressed them on it but they didn't give up much info.
ditkafan1985
NOVA
2023 F-150 Lightning Platinum
When I had the dealer do my sensors, I brought this up very transparently and the response I got was, we knew by learning the hard way, but have a good power source on the 12V system now.... Not a great response, but better than it could be 🤷‍♂️
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
This is a big deal. Anyone that’s struggled with OTA and has “general system performance” issues can now get a lot of most important modules updated courtesy of Ford.
The most exciting for me is that BCM is included since that one provides WAL functionality and I cannot update it myself through FDRS.
I do have no audio on CarPlay about 1 out of 5 times I get in the truck so I have a legitimate issue but unless some new updates also appeared with this TSB I doubt an update to my BCM will fix the issue.
I though I was the only one with no audio through carplay at times. I also very rarely get all speakers off on one side of the cabin, but it does happen like once every 3 months or so.
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
I think a lot of people have the silent carplay issue. But I thought I was the only one on the speakers except mine is the rear will stop working. Bout as frequently as you say. Half the time though it happens I probably don't even know because I'm the only one in the vehicle.
jetfixr1
Manny
Atlanta
I have to double check im not going insane by going to the audio settings and moving the ball around to the side that I think is not working.
zeus2023
Louis
Lightning Lariat ER Agate Black Metallic
I have experienced some issues with Carplay......I also don't have AM radio. I have an AM tab next to FM and SiriusXM but it doesn't work. At my last maintenance interval the dealer said that Ford was working on it. Could this TSB be the solution?
Effonefiddy Lightning
Alfred
This is a big deal. Please read through this carefully.
TECHNICAL SERVICE BULLETIN 25-2048
(Sync) General System Performance, Stability, And Intermittent System Reboot, Intermittent Wireless Apple CarPlay Or Android Auto Function, Phone Related Concerns With Intermittent No Audio Or Static, Navigation/Global Positioning System (GPS) Related Concerns Through Apple CarPlay And Android Auto, Alexa Function Consistency And Stability
24 February 2025
Model: Ford 2021-2024 F-150
Markets: North American markets only
Issue: Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions:
• General system performance/stability/intermittent system reboot
• Intermittent wireless Apple CarPlay or Android Auto function
• Phone related concerns with intermittent no audio or static
• Navigation/GPS related concerns through Apple CarPlay and Android Auto
• Alexa function consistency and stability
This may be due to a concern with the software in the APIM.
NOTE: The APIM software update that addresses the symptom listed in this bulletin may have been sent via a software update delivered OTA to connected vehicles that have automatic updates enabled through the center display screen. Enter the VIN in PTS and check the OTA Dashboard under the Connected Vehicle tab for OTA update history. If an update to the APIM has successfully completed recently and the customer is reporting the symptoms are no longer present, this article may not apply.
Action: For vehicles that meet all of the criteria in the Issue and Model statements, follow the Service Procedure to reprogram the APIM.
You can read the rest of the details in the attachment....the modules that would be updated by this TSB (if updates are available) would be the
  • GWM
  • APIM
  • TCU
  • IPC
  • BCM
  • CMR
  • SCCM
  • IPMA
So it's pretty comprehensive.
Note: Another version of this was also released specifically for the Mach-E (21-24) and it's interesting that in that version they list the 36Ah battery as a part that should be replaced as required, but in the F-150 version the Lightning's same 36Ah battery is not listed, but the ones for the ICE and Powerboost are.
Thats been happing to mine from day one.
FloridaMan655321
1973 F100, 2024 Flash
I haven't had any of these issues, but I guess because I wire in the carplay and not do wireless, and don't use my speakers for calls, and don't use alexa. I guess I'm too old for some of those things haha
GoodSam
Good
occupying space
I hope this will fix my Ford "Navigation" that is currently putting me out in the ocean! (Wireless Android Auto, Google Maps or Waze app, gets affected also, which is strange, as I would think that those apps would be separate from Ford Nav, getting location from cell towers, T-Mobile. Maps tries to properly show location, but eventually falls over to the Ford Nav failure to know where I am.)
This TSB 25-2048 seems to finally complete this old Special Service Message 52574 notification, from May 2024?:
https://www.f150lightningforum.com/...4-solutions-being-developed.19619/post-393199
SSM 52574 Vehicles Equipped with SYNC4 - Intermittent Symptoms After All Available Software Updates Performed - Awareness of Solutions Being Developed Some vehicles equipped with SYNC4 may exhibit one or more of the following symptoms after all currently available accessory protocol interface module (APIM) software updates have been performed.- General system performance, stability, and intermittent system reboots.- Intermittent Wireless CarPlay or Android Auto function.- Phone related concerns with intermittent No Audio or Static.- Navigation/global positioning system (GPS) related concerns through CarPlay and Android Auto.- Alexa function consistency and stability. These symptoms may be due to the software in the APIM. Replacing the APIM will not resolve these symptoms for the customer. Before returning the vehicle to the customer, review the procedures within Workshop Manual, Section 415-00 and ensure the latest APIM software is installed. Refer to General Service Bulletin (GSB) 23-7146 for help determining the latest available level of software. IMPORTANT: some module software updates will only display as available on Ford Diagnosis and Repair System (FDRS) after prerequisite modules areupdated. This may require the technician to update certain modules multiple times during the service visit, before the latest APIM software is accessible in FDRS. If symptoms continue after latest APIM software has been installed, inform customers that Ford is working on additional software enhancements which are expected to be delivered over-the-air (OTA) by Q4 2024 on F 150, F-150 Lightning, Mustang Mach-E, Mustang, Escape, Corsair, Expedition, Navigator, Bronco, Mustang, and 2023-2024 F-Super Duty. Software will update automatically if vehicle connectivity is enabled in the vehicle's settings. For all other vehicles with SYNC4, schedule a service visit for customers in October 2024, when the updated APIM software is expected to be available to dealers. Monitor OASIS for additional information
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I’ve noticed lately that I’m only getting right side speaker w apple carplay. Think it started with apple update 18.3.1 and it’s doing it on both 2022 & 2023 Lariat ER’s. No other of the issues mentioned. 10.3.0 came thru last night on the 2022 and knocked the LV battery down to 74% from full - a 17 minute procedure it said.
ktn
MN
2023 F-150 Lightning® LARIAT ER
I feel like this started with iOS 18...but still hard to figure out who to blame on this.
Mainly happens to me when I make a quick stop, turn off the truck and start the truck again within 5-10min.
ditkafan1985
NOVA
This was 100% occurring in ios17 for me as well.
