240V charger blowing breaker
TomB985
Isanti, MN
2022 Lightning XLT ER
This could also be a bad breaker.
I took a trip with my Model Y to California and back towing a small popup trailer. I stayed a campgrounds and charged the car from the 14-50A outlet at the campsite.
My last stop was at an old run-down campground run by the town of Armour, SD. My 32A Mobile Connector tripped the breaker after five minutes, so I ran it to the empty, adjoining site and it tripped again. I dialed down the charge current to 24A and charged without issue all night long. I don't know how old those breakers and outlets were, but they looked ancient.
My money is on a bad breaker because a fault within the truck's OBC would likely set a code and disable charging.
Ford F-150 Lightning 240V charger blowing breaker D0052582-CDB2-4149-9C4A-64818C51420B_1_105_c
SilverBrewer
Beau
Cincinnati, OH
2021 F150 Platinum Powerboost
If your charger hardwired or on a plug? I know some states have adopted new code that requires a GFCI and those don’t play nice. Mine was fine for 6 months before I had this issue and then it hardwired and removed the GFCI breaker.
Runaway Tractor
Yes
Honestly this seems more likely than the charger being bad (although not a sure thing). I'm having a hard time picturing a failure scenario where the Ford mobile charger is pulling 65+ amps for 5+ minutes and it's not a pool of melted plastic burning in the garage.
The Weatherman
Dean
South Central KY
I did see where the OP ever IDed which charger he is using? If it’s the Pro Charger he needs to check the AMP settings both dial and software.
I think the idea of it being a weak breaker is good bet.
weak breakers are common in the RVing campground world, happens all the time, and yet camper owners think that their CAMPER is to blame, or they are asking for too 'much' power...
change out to a new 30amp 120v breaker and everything goes 'back' to normal...
now, though, a weak 50amp 240v breaker is NOT as common... and I would doubt is the root of this OP's problem... but, changing it out won't hurt anything, even if it's not the issue.
I highly suspect that this MIGHT be due to a weak connection AT THE EVSE's plug, within the female OUTLET... meaning that arcing is occurring, due to a loose Neutral, probably within the outlet... which ultimately can cause overheating, transferring back to the breaker, which trips, AS IT SHOULD.
by the way, the OP's headline "240V charger blowing breaker" is using terms that don't really go with electricity, as nothing is 'blowing', whatever that even means. When a breaker TRIPS, which is EXACTLY it's one and only Job, it is a sign that more than allowed amperage is flowing thru the wires between it and the 'load', in this case an EVSE.
Nothing 'blows', although I realize some who have a fear of electricity tend to use terms that are not accurate for the situation. Or, maybe it's due to some 'old' technology, back in the day, when a glass fuse would be said that way... probably.
A breaker 'trips' due to heat buildup within the wires that are attached to it, and when it trips, it immediately REMOVES all power, and potentially all 'problems' associated with the reason it tripped: either something is asking for more power(amperage) than it is designed to handle, or something, like arcing in a 'load', or an outlet, is creating unintended HEAT. Potentially a fire, yes, but the old adage that "where there's smoke, there's fire" is a wive's tale. Untrue. The melting of wire covering or rubber or plastic coating created by heat can create 'smoke', although it's not an open flame.
Phineas Magliozzi
Bay Area
2023 Lightning XLT SR
That’s not how it works. The EVSE sends a pilot signal to the charger in the truck to indicate the maximum allowable charge rate. The charger in the truck then sets the rate.
The EVSE has no direct control of the charge rate.
My Emporia charger allows me to adjust the charging rate up to 48A. I frequently charge below 48A because the 49ers lost. Is that not "direct" control? Forgive me if I'm a bit grumpy...
Runaway Tractor
Yes
He already said it's the Ford provided mobile charging cable. 7.6kw (30 amp). Also, I think you're way over analyzing words. The breaker is tripping. He's not suggesting an explosion with a column of flame is blowing out of the breaker.
GoodSam
Good
occupying space
my 240 v breaker is 50 amp and I’m using the Ford charger provided.
It is not clear to me which charger is being used as it could be the 80Amp capable unit. I admit it would be unlikely to have been charging successfully and have the Amps allowed setting change.
see this other thread regarding a loose connection at the breaker
https://www.f150lightningforum.com/forum/threads/ford-mobile-power-cord-tripping-50am-breaker-in-cold-weather
Heliian
Make sure the connections are all tight at the breaker and plug. If they are then change the breaker.
Breakers do fail occasionally. Also check that you have the correct wire gauge installed.
The F-150 version of the Ford Mobile Charger is 30amps, not 32amps. Bad outlet is my guess.
flyct
Jerry
South Florida
Blissfully Retired
Calling the electrician is a good move. He can quickly measure the actual current the load is pulling. My guess is the cause is a weak breaker or a loose connection at the breaker. Report back what he finds.
Frankhpns
Frank
Milton, Florida
2023 Ford Lightning XLT
Retired military
I have been charging my f150 at home on a 240v charger for 1 year and never a problem.
yesterday I used a DC fast charging station for the 1st time ever.
now when at home my 240 charger is blowing my breaker in 5 min
is there any coincidence that this is now happening after I used DC for 1st time ever?
I would buy an amprobe and measure the current draw to the truck. It should be close to 30 amps about 7600 watts. If it is more, open the main disconnect to the panel and tighten the lugs, they may have become loose. If the breaker is tripping after 5 minutes you either have a breaker going bad, loose connections, defective charge cable/module or an issue with the onboard 11.5kw charger.
Calvin H-C
Calvin
This is technically true: breakers trip while fuses blow (they melt or fuse, but the common term was blow).
Old habits die hard, so when breakers started becoming more common in homes over fuses, people continued to say "blow" when a breaker would trip.
After all, how many of us say, "dial" when placing a phone call?
