Rlevans
Russ
Asotin WA
2023 Lariat F-150 Lightning
Thanks to all the contributors on this and the first Forscan thread.
Really appreciate some of these mods.
So far I have:
glarefree lights
Euro belt chime (no chime at startup)
Trailer signal camera
“Full view not available” delete
Silent mode
Global windows
PJnc284
Garner, NC
Do you get the extra camera options while driving if you do the turn signal camera mod?
The side cameras are viewable while moving with the 50/50 enabled.
This would be great to have until Ford gives us turn signal cams without a trailer. Do you have the Forscan codes to enable 50/50 view? I couldn't find them specific to Lightnings.
I have a 2023 so ymmv but below are the changes I made along with my factory values. If yours are different then the updated value will change. You're basically enabling 50/50 views for the APIM values. I also have Cameras At Speed enabled and the Full View Not Available box removed.
APIM 7D0-01-01 xxxx *xxx xx-- 3 (factory setting 1)
APIM 7D0-01-04 xxxx xxxx x*-- 1 (factory setting 0)
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1737425440431-9y
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1737425281788-5i
