HURRICANE HELP needed with monitoring power via app
flyct
Jerry
South Florida
Blissfully Retired
We just lost power with Hurricane Milton. I’m running house off the Lightning 240/30amp fine using generator inlet. I expect the power to be out at least 2 days.
I can’t seen to find ability to monitor prower output on the App like I believe I was able to do 6 months or so ago. Is there a way to view usage on the app like it can be seen on the car screen?
No longer possible since V5
I believe FORD removed that 'remote' option... no more APP info for ProPower
but, the app WILL continue to show you the KWH of power, or MILES...
which is really the important part, I suppose...
duncanmaio
Duncan
Norwood, MA
2022 Lightning Lariat Atlas Blue
I don't think so.
What you do want to do is to make sure that the Pro Power reserve setting is where you want it, automatic shutdown is disabled (so the truck will stay on indefinitely) and shut off lights, climate control, etc. to minimize power consumption by the truck.
Stay safe.
CyclopsThere
Portland
2023 XLT
I think they removed it. YOu can see truck charge but I haven't found Wattage use per circuit like you can find in the truck. Same exact setup as yours, stay safe!
Not like you need advice but I'd start rationing power now like it'll be out for a long time!
Runaway Tractor
Yes
Yeah the elite software developers failed to include it in the latest version of the app. But don't worry, they prioritized a new Karaoke app for the truck truck. Make sure your reserve setting is enough to get you to a charger once power is restored.
Good luck and stay safe.
flyct
flyct
Jerry
South Florida
Blissfully Retired
Thank you all for replying. I’m monitoring charge and estimated range. went from 79% and 247 miles to 77% and 240 miles of range in 2-1/2 hours.. I’ve lost 7 miles of range in 2-1/2 hours. I have TV, internet, WiFi, ceiling fan, refrigerator and freezer running. Wife brewed some coffee also. Lights flickered once where I think the well pump started up.
Talked to my Son In Law in Sarasota. It’s starting To blow ”hard”. It’s only 35 mph now. He find out what hard is when the eye passes over his house. This sucks big time.
Runaway Tractor
Yes
I'm sure you know this by now but your son is in the worst place to be right now. Stay in contact as long as you can! Hope he has a high up place to be.
captcory
cory
sw florida
'23 FORD Lightning PRO, honda pilot
We're riding it out in Fort Myers FL. the water is rising. good luck .
I'm hard on Ford about the SW and the battery troubles with this truck, but I will recognize that in the last month alone this truck has made a very positive experience in quite a few lives as "backup power" that would have not had it otherwise.
I hope Ford can still get their next platform together and get beyond the problems they do have. They've wanted to diss the platform and note they want to support Hybrid, but there really plenty of others ready to fill in the gap.
Scorpio3d
SS/IBA car wash owner
Hope you all stay safe and hope the truck help you make it through!
Danface
Central Mass
2023 Lightning XLT
The truck should show you how much is being pulled on each of the 120 volt legs (mine does).
Stay safe!
flyct
flyct
Jerry
South Florida
Blissfully Retired
Stay safe!
Yes it does, About 340 watts per leg unless the water pump runs.
johnnyonetime
FL
2022 Lariat ER
We’re 20 miles SW of Daytona Beach on I-4 and lost power from Hurricane Milton 4am this morning. Ran 2 cords to power refrigerator, TV, internet, Wi-Fi, microwave and small lamp. That’s enough to get by for awhile. Permanent solution that includes solar in our future.
Ford F-150 Lightning HURRICANE HELP needed with monitoring power via app IMG_1419
