Priority Update-23-PU1113-UNX-DC [Connectivity]
rugedraw
Javier
Miami
Auto Sales
As usual downloaded while I was out not on WiFi but this time installed while I was out as well (While I was in the store). Still reading the forum trying to see what is changed in "connectivity".
This is to address a config issue within the TCU where the country code was changed to a country out of the US. If you or anyone is able to connect to Fordpass, then you are not affected by this issue and the OTA will come in without being connected to wifi.
Fast87t
Gary
Ohio
2022 F150 Lightning Lariat
Does anyone know why after the OTA update 23-PU-1113-UNX-DC the Android auto will not connect wirelessly to our phones?
EdRudy
Ed
Springfield, VA
Mine partially installed and says Update "Not complete". It's been in this state for over a week now.
rugedraw
Javier
Miami
Auto Sales
First time I hear of this being reported. The updates makes a small config change to the TCU and your phone does not connect directly to that, so I am inclined to say it is not related.
That means the OTA most likely failed. Send me your VIN and I can confirm.
EdRudy
Ed
Springfield, VA
I sent my VIN to you.
AmandaB
US
2022 Ford Lightning Lariat ER - Red
I got this update yesterday while I was driving.
Got this early in the morning while I was ...... you know on the road, my fear was that it might break something for the Tesla Supercharging demo, lucky it didn't
Fast87t
Gary
Ohio
I'm still waiting for tesla supercharger ota update. I was lucky to get nacs adapter reserved #4615 earlier.
Odd issue with Remote start and Departure timer since this update
I'm no longer getting the seats or steering wheel warmer to run using these start modes.
When I get in the truck and start it, the indicators lights are off for both heaters, I can turn them on and all is good at that point.
If I do not use the remote start or departure timer, but simply start the truck while in the driver seat the last used modes seat heat level and wheel warmer conditions remain as last used.
I checked my "Remote Start" under Vehicle Settings all seems as it should be, with settings Auto / Auto / 15 Minutes.
The conditions I set for departure timer included the "Warm" condition.
I've sent a voice report to Ford via the Sync screen to let them know.
Repeat departure timer 7:50, while unplugged, went out at 8:00 this time the driver seat and wheel lamps were on and moderately warm, and after push to start, resumed warming on the drive.
After breakfast, I used remote start, waited five minutes then hit the push to start truck. indicator lamps for the seat & wheel were off, manually switched them on and all is warming afterwards.
I'm going to tweak my Tuesday test, set departure time for 7:00 am (primary day hitting the polls early), as always it will start t-minus 5 minutes, by the time I get in the truck 5-6 minutes will elapsed, maybe that's the sweet spot now??
Departure timer, activated on schedule, un-plugged mode, seat & wheel cold
Push to Start, activated seats & wheel manually, they warmed up normally along the drive
Later in the day tried Remote Start, similar situation, once hitting Push to Start, manual activation made them work during the drive.
Second test of Remote Start, with toggling from Automatic to Last Setting used didn't change the results, last use was seats on 1 & wheel switched on.
flyin525
Richard
Youngsville, NC
Disappointing that the finally got it working with departure times this winter, only to break it again.
Gimme_my_MME
@TaxmanHog what's your ambient temp when it starts? What about changing it to cabin temp hot and see if it runs heated seats and steering wheel?
GoHawks
2022 Lariat Lightning ER
Anyone experiencing PAAK issues with this update? I received this and the Tesla P&C update this week and now PAAK isn’t working on my truck. Thanks
Outside temps High 30 to mid 40's today, I had cabin HVAC set to ~72/73°
I'll try increasing it now & see if the change get's the seats & wheel pre-warming going again.
