Just INSTALLED: L2 48A EVSE from Amazon - getting prepped for incoming Lightning
FlasherZ
St. Louis Metro
I’m running 6-3 from 60@ breaker through wall to 14-50 receptacle in weatherproof enclosure outside. Will use mobile charger initially. Will go to 100@ breaker, 2 gauge wire to pro charger if it ever shows up. Not very expensive when only need 6 feet of wire.
A 6/3 cable is not legal for 48A EV charging load. 60A of conductor ampacity is required, and 6/3 NM only provides 55A ampacity. Wire-in-conduit is legal because at 75 degC column, you get 65A ampacity.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
You’re correct. The 14/50 is “temporary” and dedicated to 32@ mobile charger. Wiring run will be replaced when CSP is installed because I don’t need both. I should really get a 50@ breaker but 60@ was available. It’s safe but not code. I’ve just convinced myself to go to HD and get the 50@ breaker
jefro
F150, Corvette, Bolt EV,
Then you have to de-rate the evse to 40A output.
ResidualJinx
Erik
BMW X7, F-150 Lightning, Kia EV6
As a UL employee I greatly appreciate the fact that consumers care enough to know the difference, most people would just take the non listed one as they don't understand the difference.
Can you help me appreciate the difference? lol idk which version I just bought but it was $399 so I'm thinking it's the non-UL version.
ResidualJinx
Erik
$300 install cost by my electrician to install the 48A Emporia charger - total cost $750 including charger:
I'm not too far from Montclair, would you mind PM-ing me your installer, that's much better then I've been getting quoted to install!!
ResidualJinx
Erik
That's the one I'm getting installed, I have there power monitors and there app is rock solid helping me keep track of my solar production. You should consider getting the power monitors if you have solar. You will be able to charge only when solar is sending power back to your service provider if you choose to.
This is a awesome combination.
Craig, who are you going with to install yours? I just picked one up and we may qualify for a $250 rebate thru South Coast AQRB if we get it permitted.
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
In the most simple of terms UL certification means it passed a third party inspection. For something to be UL listed they have very strict guidelines in regards to design and the components being used. Without this inspection the parts can be sourced from anywhere with no safety certifications. In this case i would assume they two models are the same just one doesn't come with the certification, however they could be using different parts.
CRAIGC540
Craig
Moreno valley
Technician
My installer is a licensed and self employed that was recommended from my neighbor who had a Tesla charger installed. I had him run a 60amp breaker direct to the Emporia charger and a nema 14-50 so I can plug in the Ford charger if needed.
Great minds think alike.
Ford F-150 Lightning Just INSTALLED: L2 48A EVSE from Amazon - getting prepped for incoming Lightning Screenshot_20221004_140228
CRAIGC540
Craig
Moreno valley
Technician
I like this charger better its faster and free.. 😊
Ford F-150 Lightning Just INSTALLED: L2 48A EVSE from Amazon - getting prepped for incoming Lightning 20221002_031237
Yep just incase the Emporia is down.
I added the 14-50 because the wife is getting a Mach-E. When I get the charger that came with my truck, I will hardwire that and put the cord back on the Emporia and use it to charge her car.
metroshot
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
PM sent
metroshot
metroshot
Pat
Montclair, CA
Networking Tech
We are sharing the same 48A charger.
Wife has PHEV now but has 2023 MME ordered (priority 1) charged in the garage.
Lightning gets a charge once a week on a weekend day outside.
Ccarm6
Birmingham, AL
Future F150 Lightning
@Pioneer74 And @CRAIGC540,
why did y’all choose emporia? I should be picking up my demo lariat ER in 1-2 weeks and I’m shopping for an aftermarket charger since I do not plan to use backup power and 100A breaker would be a stretch on my current service and thus do not have much of a need for the FCSP and will sell it. I am having a tough time choosing the best 48A charger. Looks like juice box may include a 30% EV credit for cost of materials/install up to $1K and seems to be well recommended. I don’t have solar so the need to integrate isn’t a priority of mine. Also, y’all mentioned wiring a NEMA 14-50 in case the emporia is “down”, why would it ever be down? Just want to make sure I’m purchasing the right charger for my needs. Thanks in advance
