FlasherZ
- Mar 10, 2022
- St. Louis Metro
- F-150 Lightning, Tesla Model X, F250 SD diesel 6.0
A 6/3 cable is not legal for 48A EV charging load. 60A of conductor ampacity is required, and 6/3 NM only provides 55A ampacity. Wire-in-conduit is legal because at 75 degC column, you get 65A ampacity.I’m running 6-3 from 60@ breaker through wall to 14-50 receptacle in weatherproof enclosure outside. Will use mobile charger initially. Will go to 100@ breaker, 2 gauge wire to pro charger if it ever shows up. Not very expensive when only need 6 feet of wire.
