DCTrentster
99% certain the problem is a factory recall on the 12v charge sensor. Bringing in the truck tomorrow for the recall. Tech said that it's likely the 12v charge sensor that is causing the update to fail. Check and see if you have a recall pending.I am having the same issue, every update fails numerous times. I got a letter from Ford yesterday saying they are replacing a Low voltage battery sensor because it is sending false LVB battery information and interfering with downloads.
