jjerabek
You are right. The only reason is that for my application/business case, I will need 2 trucks anyway, in a remote place where having a 100kw battery with Pro Power on board is a boon, but no chargers.Is there a reason you’d hesitate to use a 10,000W generator and a 40A mobile cord to keep the truck charged as needed? Direct electrical generation is most likely to be a more efficient method.
While you are correct in terms of losses through powertrain, IF (big IF) I can pull the Lightning for 100km and recharge 40-50kW and have a 10l extra fuel consumption, I am looking at a $20 fuel surcharge. 40kw at a supercharger can be anywhere from $20-25 so really not that huge, plus you save 1 hour of fiddling around chargers if you can even get one in remote locations.
Excellent points. I am tempted to rent an HD truck to try.
