tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
Is there any way to get side mirror video when turn signal activated without towing?
PJnc284
Garner, NC
Some have used something like https://a.co/d/0Q1ACqW to fool the truck into thinking you have a trailer. You lose Blue Cruise, cross traffic alerts, etc though. There is also the option of 50/50 views which shows both side cameras but requires you to hit the camera button.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1000007890
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
Enable Silent Mode (AKA campground / dark / police mode)
Creates a SYNC toggle to turn on/off Silent Mode. Silent Mode turns off cluster lighting, welcome lighting, courtesy lights, SYNC screen, and silences the horn when locking doors. See this post for more info, pics, and how to enable using easy mode.
Has anyone done this yet on the Lightning successfully? Would love this feature, it would be like generator mode when truck is on and powering a campsite (I think?)
I tested it before I posted and it works. Note this is for when the truck if off and you open doors or lock/unlock it. Like when you need to get something out of your truck at a camp.
" turns off cluster lighting, welcome lighting, courtesy lights, SYNC screen, and silences the horn when locking doors."
I don't believe this is for when the truck is On for ProPower. Maybe it works for that but I didn't test. The Sync screen will probably turn on when you start the truck. When it warms up, I'll test it and update my post.
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
Ok I gotcha, thanks for the reply!
astrand1
Alex
Studio truck driver
Why are we saying (not recommended) for the DRL brightness adjustment?
PJnc284
Garner, NC
Some have noted recently that they were getting flashed more by oncoming drivers after they had increased the DRL brightness. I never did see any difference in any of the lights between the default 10% or changing it to 100%.
Because they become too bright and many folks who made the change said other drivers were flashing them and so reversed the change or lowered to 25%. It looks like you have your brights on. Posts 6-22.
astrand1
Alex
Studio truck driver
Ahh that makes sense. We should maybe clarify that in the description. I’ve not tried it yet.
astrand1
Alex
Studio truck driver
Do you get the extra camera options while driving if you do the turn signal camera mod?
sd25
NJ
F-150 Lightning Lariat ER, Rivian R1T
This would be great to have until Ford gives us turn signal cams without a trailer. Do you have the Forscan codes to enable 50/50 view? I couldn't find them specific to Lightnings.
