NEMA 14-50 Outdoor Box
Brian Black
2024 F150 Lightning Flash
I’m 6 weeks into owning my Lightning and I love it. I have the FCSP at our house and it works great.
I am looking ahead to the warmer months when my family and I spend time at our camp (that’s a lake house for anyone not from Maine). My plan was to have a local electrician install an outdoor rated NEMA 14-50 box at the camp, and use the mobile power cord that came with the truck to charge. I realize this will be slower than the FCSP, but that’s okay. I typically arrive at camp on Friday and don’t go anywhere until Sunday.
Are there any significant cons to this plan? Electrical hazards? Is that mobile cord okay left out in the rain? I’ve only used the mobile power cord for 120 charging at home in a garage. Anything else I should consider?
It works great on 240v. I would just put an awning over the plug and evse to keep water out but still allow airflow around it.
The Weatherman
Dean
South Central KY
The portable Ford charger has a max of 32 amp rate of charge. So if you are doing much driving while you’re there it could be tight. You might consider a Grizzl-e 48mini. It’s small and portable and will charge up to 48amps.
Have a great spring outing.
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 2024 Lightning Lariat AMB
if there are dcfc chargers between Home and Camp, as back up, a new charger may be an unnecessary expense. And on a 14-50 would never use the full 48amps
48 hours parked at camp with the FMC running 30 amps at 240v will have you fully charged from 10% to 90% well before it's time to return home.
flyct
Jerry
South Florida
'24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
Blissfully Retired
Watch this YouTube video. Starting at 12:00 minute mark.
Great advice to buy a Midwest Outdoor box and modify it for a Hubble 9450A receptacle.
mrau
23 Lariat⚡ER
No cons. It is a great idea and you will enjoy the convenience of charging at camp.
Agree with the recommendations to use a Hubbell or Bryant 9450 outlet. They have heavy duty connectors and are designed for constant long loads. You may also need a bit larger cover (depending on outdoor box used) since these are just a bit bigger round than the normal use outlets.
Zoro sells them but they are available at many places.
Ford F-150 Lightning NEMA 14-50 Outdoor Box Screenshot 2025-01-26 at 9.30.07 AM
Ford F-150 Lightning NEMA 14-50 Outdoor Box Screenshot 2025-01-26 at 9.31.25 AM
Brian Black
Thank you fellas. If I hadn’t asked about this here in the forum, I would have definitely bought the cheap outdoor box from Home Depot and the electrician at camp would have no idea that the plug wasn’t intended to EVs. And my camp is a is a tinderbox…
SpaceEVDriver
Arizona
I would spend a few extra dollars and install a GE/ABB/etc 70A (50A + 20A receptacles) RV load center with a breaker at the load center.
The 240 plug is a perfect setup for use with the mobile EVSE. There are a million ways to skin this cat, but yes, your idea is one that meets the needs for sure.
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2021 Mustang Mach E
happily retired!
That’s what I did! You can buy an outdoor 14-50 weather box and you also need a EV rated 14-50, sold at Home Depot . You should buy the receptical and box, most electricians are still clueless about EVs. The EV 14-50 has a larger diameter socket than a regular, make sure it fits the box!
I’ve had this Leviton EV 14-50 in my garage for six months now with no problem. I would suggest a 50amp breaker, that would give you a 40amp maximum for the evse. The Ford chargers are not known for reliability so you will probably end up buying an after market 40 amp. Most just keep the Ford evse as a spare.
Ford F-150 Lightning NEMA 14-50 Outdoor Box IMG_1152
Joe Dablock
Stewartstown Pa. 17363
What everyone said is great advice. For a lot of precipitation, you could cover the charger with a trash bag. Pick an optimum location for the plug. You could also run a heavier gauge wire in case you want to upgrade to a higher current charger some day.
david62
darlington Sc
2023 f150
farmer
I bought one of these and chopped the end off and wired to breaker box instead of using the outside box. Seemed to me like it reduced number of connections. Am pleased with it.
VEVOR 15 ft RV Extension Cord, 50 Amp, Heavy Duty STW RV Power Cord, NEMA 14-50R Female NEMA 14-50P Male Plug, with LED Indicator Handle 15A Adapter, for RVs, trams, generators, campers, ETL Listed
Ford F-150 Lightning NEMA 14-50 Outdoor Box 1738086590587-7
