Will it make it?
Winter range commute- will it make it, winter ER?
  • Total voters
    39
  • This poll will close: .
flyct
Jerry
South Florida
'24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
Blissfully Retired
Yes, you can do it.
However, your situation doesn't call for an electric truck.
A cheap and efficient car is what you need.
With his ability to use almost free TOU charging at home the Tesla is perfect for him. His efficient Tesla can be charged/replenished all within the cheap charge hours. The Lightning would take 40% longer to replenish for the same miles driven when he uses the same EVSE.
If he bought a 2022 or 2023 Lightning with ER battery and upgraded his EVSE to a 100a/80a he would be able to match the current charge time with his Tesla.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), F150 L
Why don’t the new models charge at 80 amps? I love being able to come in at any level and know I’ll be full before I have to leave again!
flyct
Jerry
South Florida
Blissfully Retired
The Charger is actually built into the vehicle. The Level 2 EVSE you install at your home only supplies AC voltage to the vehicle's On Board Charger.
The Dual OBC found in all Ford Lightning ER trucks prior to 2024 was an effective 80amp charger and can output 19.2kW. The Single OBC found in the SR trucks and most 2024+ Lightnings is a 48amp charger and can output 11.5kW.
For 2024 only Lightning Pro can be equipped with Dual OBC as an option for Fleet customers.
"Smash&Grab, post: 483012
plug into a 6.2 kw level 2 charger- BUT I leave work in 6 hours +/-
Unit says apx 39 kw sent.
charging at home
His question was if he could do it under these circstances. A long range Tesla would do it. Ioniq 6 or even 5, kia ev6, rivian, etc could do it. The ER lightning could do it.
My point is that a truck is not a good option for commuting efficiently for one person at those distances. A cheap 4 banger car would be better suited.
biers
Thomas
SW Washington
eGolf
I would do this in my SR but as others said, you’d want have reliable DC chargers along the route for nasty days or days the L2 charger at work is busy or broken.
Smash&Grab
Alex
Tesla Y, Zero DSR,Zero FXE
Artist
Amazing info!!
what do you think about loosing the heat pump?
XENOILPHOBE
DC Swamp
2024 F-150 Lightning Platinum, 2024 Tesla Model X Plaid, 2024 Model Y AWD
Retired Army
Buy the GM EV and then you wont have to worry about the range and it comes with enough storage that it would take 15 Tesla power walls to provide the same storage.
https://www.gmc.com/electric/sierra-ev
0:00 2025 GMC Sierra EV Denali 00:24 Range 01:02 Charging capability 01:17 Horsepower numbers 01:51 Interior and Exterior details 03:20 Driving impressions 04:12 Multi-pro mid-gate 04:30 Towing capacity 04:52 More driving impressions 06:38 4-wheel steering and Crab Walk 08:40 Trim levels 09:02 Pricing 09:51 Out boarding charging and GM charging solutions 10:29 Safety features 10:45 Super Cruise and towing adaptive Super Cruise
flyct
Jerry
South Florida
Blissfully Retired
Amazing info!!
As a Floridian, I can't answer that question with any accuracy since we rarely use the heat. .
Smash&Grab
Alex
Artist
ABRP says…
Starting w 90% arriving work at 49%- 6h at 6.2 charger gets me to 78% and arriving home at 35%. Does that sound accurate? It says It adjusted for typical weather at time of year. Thoughts?
B177y
Northwest of Northwest WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
ABRP says…
Sounds right to me. Start at 100% with a departure time/precondition and it really shouldn't be a problem.
flyct
Jerry
South Florida
Blissfully Retired
ABRP says…
That seems to be accurate BUT will you be able to totally recharge at home during your very inexpensive Off Peak Rate hours? You would need to replenish 55% of the battery to go from 35% to 90%. The 2024 ER battery can max charge at 48 amps on a 60 amp circuit if you have an EVSE that has the capability. 55% is about 72 kWhs of electricity.
Check my math:
Considering a 10% efficiency loss on the charger
  • At 48 amps (11.5 kWs) it would take about 7 hours
  • At 40 amps (9.6 kWs) it would take about 8.3 hours
  • at 30 amps (7.2 kWs) it would take 11.1 hours
My typical Monday (127 miles from upstate to long island- mon and weds 52ish times a year)
He should be able to recharge, even if spread within TOU limits over 2 days (Mon/Tue then Wed/Thur)
Smash&Grab
Alex
Artist
ABRP says…
Check my math:
That is good info- yeah I would be out of TOU by a few hours.
If I get a 2023 then I can amp up? But loose the heat pump. Thoughts on that
Smash&Grab
Alex
Artist
ABRP says…
So I adjusted for 20 degree weather (both legs) and 90% start charge and it says I arrive home with 20+%
That would mean I would use 120kw of energy for 256ish miles 2.1m/kw?
The calculator is accurate on my tesla from last weeks cold snap- but 2.1m at 20 degrees seems like quite a stretch for the Lightning?
Ford F-150 Lightning Will it make it? IMG_2644
