Have you noticed... (lesser known features of our trucks)
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
thunderbayterry
Terry
Thunder Bay, Ontario
2023 F-150 Lightning Lariat ER, Mazda MX-30 EV
Something that not even the sales people knew about.
The tailgate pull out step has 2 pockets that hinges that allow a bar clamp to be inserted and then clamp your materials down to the the tailgate.
If you look close enough you can see the graphics that show the clamps.
Rick
I find it shocking how little the Ford sales people known about their EVS
21st Century Truck
Martin
You dont need to hold it. You just push the 7/8 button like you would your code.
My preteen nephews use the B Pillar keypad all the time. They love it... no fob to lose, makes them independent of me especially when we camp somewhere. Too bad that Ford didn't put the B Pillar keypad on both sides.
Max Power
Max Power
Mid-Atlantic USA
I also LOVE this feature. I regularly drive to a trailhead for a run and love that I can lock the truck and not have to hide a key somewhere. Now that I think of it, does anyone know if a smartwatch capable of running FordPass works like PAAK without needing to have your phone on you?
Max Power
Max Power
Mid-Atlantic USA
Another feature that had me stumped for a while was the locking rear underseat storage (for those with this option). I could certainly figure out the storage tray, but it took me digging through the owner's manual to find out that the lock is actually a lock of the rear seat bottoms accessed via a keyhole on each side of the rear seats. Said keyholes were, in my case, hidden by the seat belt straps!
djstough
Outside Baltimore
2023 Lightning Lariat, 2023 MachE Premium ER
I just noticed this yesterday. If you stop and leave the truck in drive and then turn off the truck, the gear selector automatically changes to park.
I love this. I had this in my two prior Mercedes SUVs, albeit there wasn't a physical shifter. But I love just turning off the truck and it making sure you are in park!
Whammy Bar
Reliable - 1971 F100; Unreliable - 2022โšกLariat ER
Depending on your trim and vehicle manufacturer, sometimes, you can just walk up to your car, start it, and drive away.
When you walk up to the lightning and hop in, the check engine light illuminates sometimes (possibly to remind you that there isn't one).
Scorpio3d
SS/IBA car wash owner
Same thing happens if you open the door when you are in drive!
Reactions: N87
ryun
Earth
Here's another one I thought of for standard range trucks: figuring out your remaining miles is easy. Great if you want to double check that the guess-o-meter is accurate. Our battery packs have about 98KWh* of energy stored at 100%, so let's just round to 100 KWh to keep the math easy. Now your percentage remaining is effectively your KWh remaining.
Let's say you're traveling down the highway and you get the following info from your dash:
Battery Percentage: 55%
Energy consumption: 1.8 miles per KWh
Confident that's the lowest efficiency you'll see? Just double your battery percentage. Doubling it means you think you'll get 2 miles per KWh. In this example, that's 110 miles remaining. Making it somewhere that far is a stretch.
Aren't that confident and want more of a buffer? Add roughly half of your battery percentage to your remaining battery percentage. So, 55% +27% = 82 miles remaining. Doing this means you think you're getting 1.5 miles per KWh.
Aren't confident at all because you're towing a trailer and you've been going downhill for the last half hour? Just assume your battery percentage is now your remaining miles! 55 miles. Doing it this way means you think you're getting 1 miles per KWh.
...or you can just ask Siri/Alexa/Google in the truck: "Hey {digital assistant} what's 98 times 0.55 times 1.8?" and they'll give you the precise answer. Which in this example is 97.02 (miles).
* For anyone wondering for extended range trucks I think it's 132 KWh of stored energy, but somebody please correct me if I'm mistaken.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
My experience is that there wasn't anything about the truck that the salesman knew anything about. Could be worse, the person at the Chevy booth at the MN state fair this summer said that Chevy doesn't have an EV truck...
Note the I have used the clamp points several times :)
Granted I researched the eff out of this truck before I bought it, during the test drive the sales guy had no idea what 'one-pedal-drive' was. That's not even unique to a Ford EV.
Then again I'm damn near 40 but look like an overweight 19 year old, so they threw the rookie at me.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Unfortunately no flag on the Lariat.
I have the exact same truck, 2023 Ford lariat ER. I remember seeing that as a feature but I can't remember if I've actually checked my own truck
HaroldCal
Harold
Las Vegas, NV
2x F150L MY2023 (1 Plat, 1 Lariat)
Depending on your trim, when you fold the driver's side part of the rear seat back down, there can be quite a bit of room back there, much of it behind the fuzzy wall covering stuff. I guess higher trim models have audio gear and such there?
I think my Platinum has audio gear there, iirc. But yeah, if the space is open, would be a good place for one of them BuiltRight Molle panels with emergency gear or some such. Med kit, loaded mags, whatever. Out of sight so not likely to draw attention.
