Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits
Also got notification update was ready. It's scheduled for 3:30am, looking forward to see that SoC in the morning.
Installed no problem, like Christmas morning when I saw the SoC icon. I'm still floored that no one at Ford thought it would be a good idea to advertise they added it. One of THE most requested things, and nothing. I just don't get it.
NCMike
Raleigh, NC
2022 Red Lariat Lightning
That's weird, none of the recent 3 or 4 updates have wiped my presets!!!
Are you preconditioning or remote starting the truck then later jumping in and the FOB/PAAK failing to load your driver profile (common issue) hit the seat number you remembered your settings and profile to, this impacts radio preferences.
My driver profile is always selected. It remembers my other selections like seat placement, one pedal, etc…. It’s just the radio presets are lost.
GoodSam
Good
occupying space
Got it today, but FordPass is not showing it as upcoming or completed (update: a few minutes later, the update showed in FP). And only 2 tires on right side are showing their pressures, same in FordPass (update: Hours later the tire pressures updated for all 4, so as TaxmanHog states below, full updating of the FordPass takes some time).
Got it today, but FordPass is not showing it as upcoming or completed (a few minutes later, the update showed in FP). And only 2 tires on right side are showing their pressures (Same in FordPass).
It'll take a couple hours for all the tracking databases to sync up at the mothership.
SmoothJ
New Jersey
2021 F150 HEV
Not sure if has been mentioned, but it included these updates:
Quality Improvements include:
- Improved notification strategy when the frunk is open.
- Removed pop-up of rear brake assist unavailable under certain conditions.
- Removed incorrect Cross Traffic Alert pop-up
- Corrects pop-up message for "Neutral Tow Enabled", previously it incorrectly displayed "Emergency Tow Enabled".
- Improved 12V key off load
- Customer will now get message in Ford Pass when tire pressure is low
I wonder what this might mean on a deeper level? Lots of room for interpretation. Maybe they've figured out the 12v needs to be charged more often to support loads?
SmoothJ
New Jersey
2021 F150 HEV
Not sure, but I would interpret that as shutting off certain things that need the 12V to conserve battery power. This could potentially help with updates since that might be one of the key factors as to why the trucks don’t update.
jerock
Jerry
Kansas
Received it first thing this morning after I was unable & it gave up on, Priority Update 23-PU0306-BCF-DET
jerock
Jerry
Kansas
After the update my Fordpass only shows pressure for 2 tires, but my reading from my OBD shows 41 psi on one tire and 146 psi on 3 tires. I'm waiting for tires to start exploding!!
Lytning
Georgia
Mine installed yesterday. I did not go to Total Wine, as required for the past 3 updates, but I did go across the street from it to the Xfinity store. It is about a 20 to 25 minute drive, so that likely has something to do with charging the 12 volt battery. I got the update notice when I arrived at the store, but it did not automatically install this time while I was inside the store. (That turned out to be a good thing per the next paragraph.) I initiated a manual update when I got back home. A message posted that the update would take 15 minutes.
About 90 minutes later I went out to my truck to check the update status. The driver door would not open as usual when touching the handle. I had to use the key fob to unlock the door. When I attempted to start the vehicle I received a "key not detected" message (the key fob was still in my hand), and the vehicle would not start. I got out, locked the door, unlocked the door, tried to start again, and the key was still not detected. On the fourth try I realized that I had the driver's door open, so I closed the door, tried again, and it finally started. Both screens booted up and after about 30 seconds the "key not detected" message flashed up on the driver's console for 1 or 2 seconds. Everything seemed normal after that.
So, it appears it takes some unknown amount of time after an update for the primary vehicle controls to sync up, too.
Galactus55
Gus
Ontario - Canada
Hmm :unsure: never noticed will have to look.
Now Ford add Camping mode, and PIN to drive
Update, I recieved the Power-Up 22-PU0930-RBA-CHM on July 25,2023
Ford F-150 Lightning Priority Update: 22-PU0930-RBA-CHM: Frunk Chime Vol, SOC digits 1690389140819
Percent charge now showing on Trip screens handy little addition. ;) (y)
Lytning
Georgia
I have to give Ford an "Atta-Boy" for this. We owners on this forum asked for this and Ford made it happen. There is hope that Ford is listening and responding to the other issues and requests presented here, too.
GoodSam
Good
occupying space
For me, Ford (@Ford Motor Company) needs to earn a few more "Atta-Boy's" by restoring the EV Driving log and not missing any Charging Logs or other logging. They update one thing and regrade another couple of things. So much more is needed on our instrument panels and FordPass apps, like charging rates, digital temperatures, etc and other OBD information access. Should be so easy to do? Sad.
Jim657
Guelph Canada
23 F150 Lightning Lariat , 22 Mach E GT
Just wondering if any from Canada has received this update with the new SOC on dash? I have been drive the truck most days and still nothing.
