USA414
NJ, USA
2022 F-150 Lightning Platinum, 2012 Boss 302
Well, this is a really tough first post here, but it seems I may be in a situation where my IPMA might be bricked and am now in need of a service appointment.
Short story on this one is, I was in the process of updating modules back on 9/27 via FDRS and the application crashed on the laptop I was using towards the end of the update, and was therefor never able to push/check final configurations, or collect any data from the module/update and report back. Since that point, my power steering has been finicky, truck has been acting strange (chimes/noises), and after today's round of troubleshooting, I now have a front camera fault, service required message.
Slightly longer version is I performed several other updates without issue before attempting to update the IPMA with two Clore PL2320's, and had no issues with voltage drop until almost half way through the IPMA update where at points it hit the low to mid 9 voltage range. Not sure if this is what made FDRS crash, or simply coincidental.
Fast forward to today, I purchased a more substantial power supply (75 amps) for programming, got a newer/more capable laptop for FDRS, and attempted to perform a PMI on the IPMA which just resulted in a bunch of errors, and now a front camera fault, service required message.
VIN is 1FT6W1EV3NWG02334 for anyone with FDRS who can see the vehicle history/logs.
I've tried just about IPMA related configuration option in FDRS, resetting the the truck by disconnecting 12v power for 30 mins, rebooted the IPMA module in FORScan three times, scanned and reset codes multiple times in FDRS, but still cannot perform a PMI on the IPMA.
Anytime I do, I receive an initial message stating, "The module configuration has failed, Would you like to retry?" followed by "Procedure Unsuccessful - WriteDirectConfig, Exception writing configuration to module" leaving me completely stumped and feeling like I am out of options other than it needing to be seen by the dealer.
Thanks in advance!
Thankfully I was able to get these issues sorted, so I wanted to take a moment and thank @rugedraw @ChrisCon and @Gimme_my_MME for their support.
In addition, there were some important lessons learned on my end which I thought I'd share here:
  • Having a capable power supply is essential for larger updates (2x Clore PL2320's won't cut it for larger, more power intensive updates)
  • Either something in FDRS or the module update process has changed since I first started down this road in the middle of 2023 with my original FDRS laptop, where you should make sure you have a capable FDRS laptop as defined by Ford.
  • Set aside enough time to complete these updates. Over the past week or so, I've created a OneNote notebook for myself which has a preprogramming checklist in terms of installing FDRS laptop preparation, power supply prep and voltage calibration, and in vehicle setup before I start. I've also taken notes on which modules require a flash drive, which take longer to install, those that are more power intensive (which strain the 12v system), and lastly tried to canvas this forum as well as the Mach E forum to ensure specific updates are done in a particular order.
It's hard to say that any of what I mentioned above would have prevented FDRS from initially crashing and the IPMA update from going through, but I certainly feel much more confident now about performing future updates after this crash course!
USA414
NJ, USA
I also noticed something in FDRS when looking through the vehicle history. If you hover over the "Resource ID" column over the GXXXXXXX string, it will show you a version number. It only seems to do this for more recent updates, but I thought this was interesting in being able to identify the module and version details.
I didn't see this mentioned anywhere else on the thread, so sorry if someone else already spotted this and called it out.
Ford F-150 Lightning Lightning Software Updates using FDRS 1728585833786-m
Mike G
Mike G
N. AL, USA
It does the same thing if you hover your pointer over the update in the list of available software. But that ‘version’ number isn’t really that useful as a reference.
Jim Lewis
San Antonio, TX
Dumb Newbie Question: I asked ChatGPT about the order in which modules should be updated in FDRS. It mentioned the guidance features of FDRS. But the advice I liked best was the last tip it gave me:
  1. Update All Modules Prompt:
    • FDRS often has a feature that allows you to update all modules with available updates. If you select this option, FDRS will automatically update them in the proper order.
    • This is the easiest and most reliable way to ensure everything is done correctly without worrying about individual sequences.
Wanted to ask you FDRS experts if this is pretty good advice or an AI hallucination. Also, the first subitem says, "FDRS often has a feature that allows you to update all modules..." Does there have to be a number of modules with different dependencies, or does Ford have to prime a module update for this feature to show up? At $50 for a two-day session, I haven't been motivated to try FDRS more than once, but the UPDATE ALL MODULES prompt sounds about my speed, something that would ease my concerns about screwing up! :)
USA414
NJ, USA
While I'm not an expert, and will defer to those here with more experience, I'm happy to share my thoughts/notes as I understand the process.
I do not believe there is a "scripted" way to kick off an "update all modules" process in FDRS. I know there is a "download all option" in the Toolbox tab/ribbon which requests FDRS downloads all available packages from Ford's servers to the laptop so there are locally cached copies. However, even if you do this, I believe you will still need to execute the updates in an order which may not be the same as how they're listed on the right hand side of the SW Updates screen.
Also, updates like PCM usually kick off a group or multi-module update and will have a specific sequence predefined by Ford. I think FDRS is smart enough to kick off the PCM parent module first even if you clicked on ABS module, so the updates are still applied in the correct order.
Here's an excerpt from the notes which I created for myself based upon lots of reading and research across the forums, and a bit of personal experience. I guess what I'm saying is YMMV and I'm simply offering up my opinion based on my experiences over the past year or so. There are lots of other folks on here with more experience who might have different thoughts, or even disagree.
FDRS Update Process (High Level)
  • All 3 modules below must be updated first, in order, GWM/APIM with flash drive (sometimes TCU is USB) in the order shown below as per Ford:
    • GWM (first) - USB, longer update (~30 mins)
    • APIM (second) - USB, very long update (~2 hours)
    • TCU (third) - usually USB, longer update (~20 mins)
  • Then check/update the rest as follows:
    • IPC - USB, longer update (~30 mins)
    • IPMA (group) - very long update (2+ hours)
      • PSCM (~5 mins)
      • CCM
      • CMR
    • PCM (group) ~20 mins for the whole group
      • ABS
      • SOBDMB
      • SOBDMC
      • SOBDM
      • BECM
      • GFM2
    • Whatever else remains, but just like the updates listed above, you should research/validate in forums for any known issues
      • BCM (~5 mins)
      • RFA (~20-30 mins)
      • DC/DC (~5 mins)
      • FHCM (~5 mins)
      • DDM (~5 mins)
      • DSM (~5 mins)
      • HVAC (~5 mins)
      • PDM (~10 mins)
      • RGTM (~5 mins)
      • ACM (~10 mins)
      • DSP (~5 mins)
      • TRM (~5 mins)
*You won't usually see updates for all of the modules at the same time (unless you've had your truck for a while and this is your first time using FDRS), but if multiple updates are available, I generally perform them in the order I listed above.
**Best practice is to "Rerun Network Test" (key on/engine off) after each module update and ensure there are no errors/codes - all modules should be green. If modules aren't initialing or testing clean, perform self tests, clear codes, then retest.
Aside from the fact that I have never heard of this, I don't see how this would work since you are required to cycle the ignition on and off between updates. FDRS is fairly dummy proof. There is no reason to be timid about jumping in and doing the updates yourself, imo.
Off topic, but just wanted to post a follow-up regarding the battery cut-off switch I installed. It was super easy to do and even easier to use. I should have done it sooner.
Ford F-150 Lightning Lightning Software Updates using FDRS 20241009_144206
Mike G
Mike G
N. AL, USA
What FDRS has as a feature is the ability to download all the available updates by hitting the "Download all" on the top right above the list.
But there is no option to have FDRS subsequently install them all in the proper order to avoid dependency issues.
GWM, APIM, TCU, and IPC should always be done before jumping into anything else like the powertrain or cruise control related updates (CCM, CMR, SCCM, IPMA, PSCM).
There are quite a few of standalone updates that are short and can be done in any order (doors, FHCM, HVAC, OBCC, ACM, RFA, TRM, etc.).
ChrisCon
The Hamptons, NY
@Jim Lewis . I've been a premium Chat-GPT user and was just using the new strawberry model to research trends in current areas around me. I'm all about AI, but after reading a number of your posts, I think you understand that the LLMs are good with summaries but most of the time hallucinate with nuanced issues. I think you often read too much into the summaries you are fretting and remind you that when talking about things like FDRS, the main source of information for these models is in fact posts on forums like ours. With the data set for these niche issues being so small, I think for now it's time to stop relying or posting your copilot summaries because they are getting big picture correct, but you seem to get hung up on the things that are hallucinations/ guesses which are nearly always wrong . :)
Chat-GPT in its current state could not answer a highly technical, specific to model type , and variable to situation question like "what's the best order to update modules in FDRS?"
Jim Lewis
San Antonio, TX
A basic fact of life is few humans will want to read all the posts on the Lightning forum or wade through all the hits provided in the standard forum search interface. Microsoft apparently has bots regularly scanning this forum, and the AI interface does a pretty good job of finding forum posts and threads that address questions I pose to the A.I. So whether I want to believe the A.I. answer itself, at least the AI search typically provides a good place to start reading about a topic of interest on the forum, better than the forum's own search process.
Looking back on posts over the past half year or so, I don't see anything too flagrant that I've quoted an AI agent on (usually, it's Microsoft Copilot). If there were an Update All Modules command, which I doubted in my post to begin with, it would be sufficiently useful to ask about, whether the idea was suggested by an AI agent or not. And I did entitle my post: Dumb Newbie Question.
I think Copilot advice or ChatGPT advice is just like human advice on these forums: it could be wrong, and that's a given to start with. For example, there have been numerous declarations on this forum that one can't charge the LVB when the truck is running in full-accessory mode. Maybe many such posters never bothered plugging the truck into a charger while in accessory mode. Perhaps such erroneous answers that are totally human and not prompted by a machine (and are not even checked) are totally fine. :) To err is human, and we accept that, but machines be damned!
shelnian
Ian
Seattle
This looks like the actual Ford VCM2. If so, this is a great price for someone who doesn't trust a Chinese 2 board clone like I use.
Mike G
Mike G
N. AL, USA
Does the VCM II require it's own power brick? I can't remember.
Mike G
Mike G
N. AL, USA
Regardless...the VCM II is as fast as the current Mongoose + Ford adapter...so $259 vs the $585+/- that the Mongoose costs is no small thing. Good way to get in on the updates for a cheaper price. Well spotted @shelnian !!
shelnian
Ian
Seattle
No power brick, uses USB power or the OBD2 port power depending on what it's plugged into.
mr.Magoo
2022 Lariat ER, AMB
OK, maybe I'm overly skeptical, but what makes that the "Actual" VCM2 other than that they didn't erase "Rotunda" on the label ?
At $300 I personally doubt it's any more OEM/acutal than, say, this one: Chinese knockoff
PJnc284
Garner, NC
2023 Ford F150 Lightning
yeah, considering the cost of these trucks, why take a chance to save a few hundred bucks over the mongoose which seems to be tried and true.
